Which turbo kit for LS1 WS6?
Old Nov 2, 2003 | 09:51 AM
TurboCharged_WS6's Avatar
Default Which turbo kit for LS1 WS6?
I want to add a turbo or twin turbo setup to my WS6. I plan on everyday driving (but not everyday) and I need to know what turbo or twin turbo setup would be best and where to buy it. I want to have ~500RWHP and I an not in a hurry to replace the rear end or internals as of now and If possible not at all.
Old Nov 2, 2003 | 11:11 AM
Noyzee's Avatar
8 second mod
What city you from?
500+ to stock rear? Is it an auto?
CAS makes a nice TT set up, but hard to get unless you live in or near IL. He can make and install it, it is a nice kkit.
Other then that, QMP>>>> is doing a single kit, But again i believe they want to do install, and turbo tech also makes a single kit.
All will make good power and about the same $$$$ depends what you realy want.
Old Nov 2, 2003 | 11:18 AM
I live in Cleveland, Oh. My WS6 arrives in JAN-MARCH.. I am still looking for a good one. It WILL be a 6spd and definately a LS1. By the way how much $ are we talking for these turbo setups you mention and will they require new internals?
Old Nov 2, 2003 | 11:26 AM
Noyzee's Avatar
8 second mod
Between 5k-7k depending what you get.
It will not require new internals, But Clutch and rear will be a must after a short time.
OH, it is poss for you to do either the QMP kit or cas kit. They arnt to far from oh. il and in. Robs kit seems to be making good power, and has more avilibility I believe. But it is up to you to make the calls and find out
QMP>>>>>>>>>>
CAS. WWW.Chargedair.com
Old Nov 2, 2003 | 11:43 AM
Thanks a whole bunch for your help man! I will make the calls and do a some homework on it
Old Nov 2, 2003 | 06:47 PM
Noyzee's Avatar
8 second mod
Good luck.
Old Nov 3, 2003 | 05:39 AM
smokinHawk's Avatar
im still on stock rear
i have the turbotech kit, cheapest one out.
i picked up one used for under $3k
Old Nov 4, 2003 | 02:54 PM
jdmille5's Avatar
Originally Posted by Noyzee
What city you from?
what kind of duribility is the stock engine show?
