Thoughts on 383 with SMALLER turbo?
Old 05-18-2009, 08:10 AM
ddnspider's Avatar
Received 1,737 Likes on 1,298 Posts
Default Thoughts on 383 with SMALLER turbo?
For those not familar, my setup is a 9:1 383 w/ a T76GTS turbo, T56 w/ southbend clutch,ported LQ9's with smaller reverse split turbo cam, 3" DP tp 3.5" overaxle,etc. Running ~7psi car makes ~630rwhp. I like where the car is and how it runs and dont feel the need to turn up the boost.Car has great lowend and spools ~2500rpms.SO, with that in mind, if you were to plot it on a compressor map, its not even on the island since my pressure ratio isnt high enough for that turbo. My though is that i could swap to a smaller turbo (discussed with DR. Turbo and agreed on a TC72) and it would be more efficient thus making about the same power, but the turbo would light up like a light switch.I would venture to say almost like a roots type setup. Thoughts?
Old 05-18-2009, 08:20 AM
allngn_c5's Avatar
I say leave your setup alone. It sounds bad ***, as is.
Old 05-18-2009, 08:46 AM
moehorsepower's Avatar
Smaller turbo will spool up a little quicker, but is it worth the cost to go from a 76 to a 72?? It might be like going from a 3.23 rear gear to a 3.42. Not Much..
Old 05-18-2009, 09:44 AM
LS1Tech Sponsor
hellbents10's Avatar
I would leave it alone, when do you race below 2500rpms??? Or do you plan on heavy towing?
Old 05-18-2009, 09:49 AM
1320's Avatar
I would move the boost curve down on the 76, via a divided housing and quick spool valve first.
silverbeast's Avatar
put a small shot of gas on it and let it eat,lol. i vote for leaving it alone as well. it would suck to spend the money and then the car make less power.
Old 05-18-2009, 12:22 PM
ddnspider's Avatar
I think it would be quite a difference between a Precision T76GTS and a TC72.
The car is 3900lbs with me in it.I guess my thought process was off idle and what not.Possibly better gas mileage being more efficient,etc. I do have a 2 step now for launching so i guess thats not a big deal.Just thinking i supppose.
Old 05-18-2009, 12:34 PM
Restricted User
98Z28CobraKiller's Avatar
If you really want to spend some money to make your turbo setup "better", buy an automatic transmission.
Old 05-18-2009, 12:45 PM
ddnspider's Avatar
thankyou for the wonderful insight
Old 05-18-2009, 12:53 PM
ttranssam's Avatar
may be an idiot...but a smart one...
Old 05-18-2009, 01:53 PM
ddnspider's Avatar
yep, because thats the ticket.because EVERYONE wants an auto.Its not a track car, rarely sees the track,and i enjoy cruising in 6th on the highway @ 1800rpms getting 20+mpg.thanks though
Quick Reply: Thoughts on 383 with SMALLER turbo?
