What boost level will stock springs start to float ?
Old May 22, 2009 | 03:33 AM
BigRich954RR's Avatar
Default What boost level will stock springs start to float ?
Ok with a stock cam how much boost can you run before the springs will let the valves start to float ? at around 6-6500 rpms?
Old May 22, 2009 | 05:37 AM
EPP's Avatar
EPP
I've had stock valvesprings handle 15 psi before, but it is going to depend on your combination and how many miles you have on them. Bob
Old May 22, 2009 | 12:27 PM
Sweet stock ls2 with maybe 25k miles
Old May 22, 2009 | 12:50 PM
ls1290's Avatar
Dumb Ass Vette Moderator
The size of cam is going to be a big factor.
Old May 22, 2009 | 12:55 PM
Chronicle's Avatar
If you already have your turbo setup installed and running, I'd just leave the boost at a low level (say 5-8 psi) and just buy the springs when you graduate from a stock cam.
Old May 22, 2009 | 02:03 PM
black98ws6ta's Avatar
Ive made 500 rwhp on stock cams with a turbo car at 8-9 psi and started to see valve float. They will hold up in a supercharged car better since there will be less exhaust backpressure.
Old May 22, 2009 | 02:27 PM
98Z28CobraKiller's Avatar
Restricted User
I think that mine are floating at about 15 psi and 6K RPM. Stock long block LQ9.
Old May 23, 2009 | 09:23 PM
98catfish's Avatar
I dont think the boost makes much of a difference, Its the rpms that will be affected.
With a stock cam, why try to go over 6k or so your spinning it for no reason because you are not making any more power.
