Worth Jet-Hot coating stainless turbo manifolds?
I have stainless longtubes and I coated them - stainless *will* still rust, just not as much/easily as mild steel - even if only for looks I think it is worthwile.
definatlly worth it, keeps away from rust, a good way to keep the heat down with out the thickness of wrap (might have clearance problems)
I coated inside and out, if it flakes on the inside (worring bout turbo damage) it will flake on the outside and you alread have a bad problem if it flakes.
Sawzall and Welder Mod
Jet Hot 2000 will take the turbo heat without flaking. The stangard Jet Hot or a generic ceramic coating from a local place will crack off when the EGTs get in the 1600+ range.
On my new setup I'm getting the turbo exhaust housing done in the 2000 coating so it doesn't get surface rust like my last one did.
when I had my piping from the intercooler to the intake jet hot coated it droped my IAT 15* so i`d definatly say its worth doing the manifolds, downpipes and up pipe.
Ya it gets pretty hot on the driver side of the engine it will actually melt my wire loom after a while, I have to replace the loom every 4 months or so. so i think i`m gonna do the turbo manifold as soon as i take it off again.Thanks.
So you guys seem to agree coating both the inside and outside of all the metal plumbing and the turbo housing id good idea?..is that what I am to get from this. Just like the input...thanks!
I`m not an expert but i don`t think you should coat the inside of the turbine housing. once you spray it won`t the tubine wheel rub because of the tight clearances between the housing and wheel? just a thought don`t know for sure.
