Can i make only 5psi with a 8.702psi wastegat spring?
Restricted User
I bought a used STS turbo kit and it has a TIAL 38mm wastegate with an 8.702 pis spring in it....
Is it possible for me to run 5psi boost with this spring in the wastegate?
About what PSI will it make?
Thanks for helping out a Boost NEWBIE!
Blaine
Blaine
you can only go UP from the base pressure you cannot technically go lower.
if you put it on and it reads lower
you either have a large pressure drop due to large pipes/long pipes/ huge intercooler / bad core design on intercooler
on a rear mount, if the wastegate reference is (hose) conected at the turbo outlet/ compressor houseing, the boost pressure at the manifold will be considerably lower then spring rateing due to pressure lose through intake pipes esp if you run an intercooler as well.
So an 8psi spring may only see 5 psi at the manifold.
If the wasegate boost referance hose was conected at manifold you would see full spring rating 8 psi at manfold.
Agreed, reference it at the turbo and you may see close to the number you want.
