Va Speed's new FI machine processes/parts
Old 06-08-2009, 09:03 AM
edcmat-l1's Avatar
Default Va Speed's new FI machine processes/parts
Introducing
Virginia Speed's
2 New processes/services for higher horsepower forced induction motors.
The first is a main girdle support unlike any other on the market today. A patent pending design, developed totally in house, designed using CAD and FEA, it's the strongest piece of it's kind. BAR NONE!
It's an interlocking plate, that's dowel pinned to the main caps. The main caps are also pinned to the block. The block is machined, as well as the caps, so the plate fits tight, and become an integral part of the block.
This girdle is a part of Phil Thomas' 2500 hp LSX Mustang.
Cost is 1400. That includes all machine work, the plate, and ARP main studs.
Next is a machine process that is the cure all for high hp 4 bolt cylinder heads. Tired of pushing water? No need to run 6 bolt heads. We've got the answer. A double o-ring machining process. Sorry, no pictures for risk of being copied.
This is a PROVEN part of Brian's (Fireball) 368 inch, single turbo, 3500 lb car running 8.30s @ over 181 mph. That's at 25 pounds of boost and over 20 deg's of timing!! And they're still getting a handle on the new power!!! He has many runs on it already, and NO SIGNS OF PUSHING ANY WATER WHAT-SO-EVER!!!! At over 1500 hp, that's quite a feat.
Cost is 1000 including head gaskets.
757-468-5101
Give us a call today for all your high HP needs!!
Old 06-08-2009, 09:10 AM
veee8's Avatar
Can't wait to pick up my Virginia Speed double o-ring setup. Lifting heads and pushing water should be a thing of the past!
Hope to be back on the track in the next few weeks.
Old 06-08-2009, 09:11 AM
Fireball's Avatar
*cough* its actually 3500 lbs *cough*
Should also mention all these runs were at 25+ psi and 20++ deg of timing...not a weak tuneup by any stretch of the imagination...
Old 06-08-2009, 09:50 AM
edcmat-l1's Avatar
Thanks for settin me straight!! I'll edit......
Done.....
Old 06-08-2009, 10:14 AM
Josh@PremierAutosports's Avatar
Shawn will be getting me set up with a sleeved ls2 with these tweeks very soon.
Old 06-08-2009, 03:02 PM
TS6
TS6's Avatar
Is the double O ring something that would be considered very streetable? I wouldn't see why not, just wondering.
Old 06-08-2009, 03:14 PM
7 Second Club
Phil99vette's Avatar
Doesn't change driveability just how much power you can hold without pushing water.
Old 06-09-2009, 05:33 AM
NA$TY-TA's Avatar
Looking good guys... Alot of BIG HP motors coming out of there.
Old 06-09-2009, 08:37 AM
93formto98T/A's Avatar
I guess I missed it. What parts do I need to send you to do the double 0 ring?
Dumb Ass Vette Moderator
ls1290's Avatar
Interesting, very interesting. Are the heads and block both machined? I would love to see some pics of the process/concept, but I understand your concerns about coping. Looks like someone did their homework, good job
Old 06-09-2009, 08:51 AM
Fireball's Avatar
heads and block
Old 06-09-2009, 10:05 AM
edcmat-l1's Avatar
heads and block
Yep........
Old 06-09-2009, 01:09 PM
koolrayz's Avatar
will be interested this winter.
how much are the replacement headgaskets?
Would my main studs I already have work or are the ones your providuiding longer to make up for the girdel, If the are does it effect the oil pickup height?
Old 06-09-2009, 07:32 PM
Race your car!
JL ws-6's Avatar
At what power level is the girdle needed with a factory ls2 block?
Also, the double o ring setup, how long does it take, what's the standard turnaround time?
Old 06-09-2009, 08:18 PM
Shawn @ VA Speed's Avatar
replacement head gaskets are around 200.00 depending on the actual bore size.
yes,it affects oil pickup height-it also affects oil pan height.
there is no cut and dry power level,rpm and rotating asy weight also play a big factor in when it's needed.
2 weeks is average
Old 06-10-2009, 08:16 PM
update:30lbs of boost +21 deg of timing=no water pushed
Old 06-10-2009, 08:42 PM
Mike454SS's Avatar
In order to do the double o-ring process, do you need us to send you the block and heads, or just the heads?
Old 06-10-2009, 08:46 PM
edcmat-l1's Avatar
Both block and heads need to come in.
Old 06-11-2009, 06:30 AM
Fireball's Avatar
more like 30+ it maxed out my MAP at 30.1
Old 06-11-2009, 06:33 AM
chuntington101's Avatar
F00K me thats alot of boost! lol
what fuel are you running??
Quick Reply: Va Speed's new FI machine processes/parts
