A intercooler is a intercooler....right???
Old Jun 9, 2009 | 10:24 PM
LASTLS1's Avatar
6 Second Club Moderator
Originally Posted by DeltaT
Buy Corky Bell's book on turbos (Maximum Boost) or blowers (Supercharged!) and he has all the formulas for speccing the correct size and layout. If you have room, make it larger than you need for some growing room and a lower pressure drop. And use lots of shorter hot air channels instead of a few longer ones like many ebay ICs.
Jim
I did one better and bought his I/C. It worked GREAT!!!
Old Jun 9, 2009 | 10:45 PM
cracker's Avatar
APS does a decent job of explaining a bit...
"Vertical flow inside the APS intercooler is by far the optimum configuration given the space considerations that must be accounted for in the front of the vehicle. This solves the huge air flow restriction problems that horizontal flow cores experience particularly at high power levels.
"The horizontal flow configuration shown above forces the charge air to flow through very few internal intercooler passages. In addition, each internal passage is very long, causing further restriction to charge air flow - resulting in a high pressure drop. In other words, the long route with few passages"
"The vertical flow configuration as specified by APS spreads the charge air flow evenly over a far greater number of internal passages and results in significantly less restriction. The path length of each internal passage is also shorter, further improving air flow over a horizontal design. The net effect is a short route with many passages resulting in a massive charge air reduction but with improved air flow."
There is definitely a difference between intercoolers not only in design but form and function. Or you guys can stop playing games and put a nice A/W on it with a large reservoir/heat exchanger.
-Wade
Old Jun 9, 2009 | 10:59 PM
CamaroCoby's Avatar
Good info guys I just learned something. I prolly still go with the ebay one because of the price! LoL j/k ill. Pgo with a decent one my hp goal is only 800.
Old Jun 10, 2009 | 01:08 AM
kp's Avatar
kp
Originally Posted by LASTLS1
Yea Kevin, I think it's air flow ~ restriction. Speed has replaced just the IC and picked up HUGE hp on the dyno.
I just sold mine and I'm going to A/W.
A/W is the way to go in a drag car no doubt, I'm lazy and dont feel like dealing with the ice thing.
I'm not saying the ebay coolers are the 'best' by any means, but its hard to argue the success a lot of people have had with them.
Old Jun 10, 2009 | 01:33 AM
Sluggish's Avatar
"Best bang for the buck" maybe as far as the averaged Joe drag racing.
Old Jun 10, 2009 | 06:10 AM
pwrtrip75's Avatar
Originally Posted by ls1290
The biggest difference is the material quality. Not all aluminum is the same
I've welded aluminum for a long time, and when welding it you can tell what aluminum is poor quality and what isnt. I havnt seen a difference.
About the design...cross flow vs. top flow... thats kind of irrelevant to the "maker". You can get the cheap ones in either form.
The consentration of cooling fins.... the more fins the less air flow right? So what is better? A million fins and slower moving air? or less fins (to a degree) and more air? The intercooler isnt a 1:1 cooler meaning the heat disipates as fast as it absorbs it so if it takes 10% longer to cool after a run is it really worth $700. more?
Old Jun 10, 2009 | 10:06 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I don't remember the exact chemistry term for this, but when something heats up it takes an equal amount of time to cool off. That's the reason people run anti freeze as it takes much longer to freeze, but also longer to heat up. Versus water where it will heat up, but take less time to cool.
The ebay units heat up due to lack of proper design, but cool off quicker due to that design. The more expensive cores may take longer to cool off, but I think their superior design they'll overcome the basis of their thermodynamic disadvantage.
Old Jun 10, 2009 | 10:17 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The thermal capacity of something determines the amount of heat it can abort. The thermal coefficient determines the rate at which heat is aborted or dissipated. The thermal coefficient is the same for absorbing or dissipating. Poorer quality aluminum has a much lower thermal coefficient than purer aluminum. A good design can only overcome poor a thermal coefficient and/or thermal capacity of a material so much. Good material cost more because they are better.
Old Jun 10, 2009 | 10:38 AM
cracker's Avatar
Old Jun 10, 2009 | 10:58 AM
kp's Avatar
kp
Sure, thats pretty basic stuff. But how do you 'know' the higher priced ones are made of better material? And if they are, exactly how much better are they on a practical scale?
Swap a few around, I have..
Old Jun 10, 2009 | 11:53 AM
pwrtrip75's Avatar
The alumium on the cheap intercoolers is very high quality (ones I got). If you've ever welded aluminum you'd know the difference between shitty and good aluminum BIG difference. When you melt it (tig welding) the crappy stuff has a lot of impurities in it and welds like ****, you usually have to go over it a couple times before you burn/boil all the crap out of it to make a decent looking weld, these intercoolers are made of aluminum that welds perfect. So that rules out the material quality.
Old Jun 10, 2009 | 01:09 PM
  #32
kp's Avatar
kp
I agree, when I flipped the end tanks on one of these ICs I expected a fight welding it (like the crappy eBay IC tubing) but there wasnt any issues.
There is no doubt that fin count/placement will make a difference in heat transfer and the aluminum itself does as well. If you look at a quality core there are thinner, more numerous and better formed fins in there - no argument there. But in the end I have not seen anyone put an exact number on it, is it 5% better, 10% better, 50% better? Way too many factors/combinations to get good data.
I learned long ago that paying for quality IS a good thing, especially on a performance car. But overpaying for something you may not need, especially if you are on a tight budget, isnt prudent either. If these eBay intercoolers were falling apart, blowing out, leaking, fins falling out and going into the engine etc, I would be the first to trash them. But IMO for 130.00 or so its hard to beat, if you do upgrade to better quality IC down the road and it helps you thats awesome, you are out less than the price of a couple silicone couplers and t-bolt clamps on the old intercooler after you sell it off.
Old Jun 10, 2009 | 03:51 PM
  #33
OWN3D BY MY PROF!
That would be what I am thinking of. It would be interesting to put quantatative numbers to the differences between the intercoolers. I would like to see some testing done with the same combo. You could test the temperature each reach after a dyno pull, the IAT, and the amount of time they take to cool down.
Old Jun 10, 2009 | 05:09 PM
  #34
berty's Avatar
a bit off topic ,but i,ave been looking at these ebay intercooler for a tt set up
been looking at goodseed ,cxlighting and treadstone performance can any one comment
on any of these coolers.are these coolers made in the usa or what or are they all chinese ones
Old Jun 10, 2009 | 06:53 PM
  #35
cracker's Avatar
Treadstone actually makes a very good product. They manufacture cast end tanks, along with sheetmetal ones, and I have seen really good increases/IAT drops with their intercoolers over some procharger ones.
Old Jun 14, 2009 | 09:05 PM
  #36
irc's Avatar
irc
the first rule of thumb when figuring out size of aic you need to know your hp so you can figure out the total cfm you need to support your hp yes i know everybody knows there hp but what iam saying is you have formula that gives you your cfm you need to make your ic make and the guys on here saying the long side to side tubes really suck for any kind of cfm and vertical flow tubes with a max run of 12'' make incredble amount of cfm and fast with little to none drop just amazing
Old Jun 14, 2009 | 09:43 PM
  #37
DeltaT's Avatar
Crystal make you talk like that too? Whew!
Jim
Old Jun 14, 2009 | 10:18 PM
  #38
irc's Avatar
irc
i am a one finger typer. but know what i am talking about been in the heat transfer business for the last 15 years have built many kinds of ics air water freon and co2
just trying to lend a hand
Old Jun 15, 2009 | 02:54 PM
  #39
MaxxMitchell's Avatar
Just thought I would add, I found a boost leak in the middle of my Ebay IC, there is no way it could have been a rock or anything, must have been there all along. Unsure where it is at exactly but it is between the fins, and you can feel it blowing out the front and the back of the intercooler. A friend has ran this same company's intercooler before and it did not have a leak.
Old Jun 15, 2009 | 04:57 PM
  #40
irc's Avatar
irc
you have parting sheet leak. that is the claded sheet that brazes the fin together between the 2 passages. the only way to repair correctly is to have cut your air tanks off and block the passage off.
