5.3 twin turbo?
Old Jun 12, 2009 | 06:18 PM
mechanix565's Avatar
Default 5.3 twin turbo?
ok heres what im looking to do now keep in mind ive never done a turbo setup or an ls1 build before lol i have a stock 5.3 with 40k miles on it well it has a mild cam but thats all its out of an 02 tahoe so its got the truck intake setup which i plan to leave. the motor is going to go into my 79 mustang and i want twin turbos with a front mount intercoooler i want to use the truck manifolds because of clearance issues now here is what i want to know are there any used turbos off some other car i could use that would work alright ? what size injectors ? is a single turbo setup more practical? i only wanna run like 6 or 7 psi is that safe? i want twins so i can just figured put 1 on each pipe throw on some 60# injectors have some piping bent up and have it tuned but what is the cheapest way out of this i dont mind searching junkyards for parts and what is the cheapest way to get those injectors i was looking and the prices are outrageous
Old Jun 12, 2009 | 08:25 PM
guess no1 can help me out? im jus looking for ideas so i can make this happen
Old Jun 12, 2009 | 09:03 PM
MUSTANGBRKR02's Avatar
give it more than a hour
Old Jun 12, 2009 | 10:15 PM
nastychevelle's Avatar
Originally Posted by mechanix565
ok heres what im looking to do now keep in mind ive never done a turbo setup or an ls1 build before lol i have a stock 5.3 with 40k miles on it well it has a mild cam but thats all its out of an 02 tahoe so its got the truck intake setup which i plan to leave. the motor is going to go into my 79 mustang and i want twin turbos with a front mount intercoooler i want to use the truck manifolds because of clearance issues now here is what i want to know are there any used turbos off some other car i could use that would work alright ? what size injectors ? is a single turbo setup more practical? i only wanna run like 6 or 7 psi is that safe? the reason i want twins is because i dont know how you would go about hooking up a single because i have dual exhaust so i just figured put 1 on each pipe throw on some 60# injectors have some piping bent up and have it tuned but what is the cheapest way out of this i dont mind searching junkyards for parts and what is the cheapest way to get those injectors i was looking and the prices are outrageous
wow
Old Jun 12, 2009 | 10:27 PM
73 nova guy's Avatar
Originally Posted by nastychevelle
wow
same here
elias_799's Avatar
^^ lol, take it easy on the guy man. you can do a single turbo setup by reversing the truck manifolds and routing all the hot pipes toward the front (close to the rad) and that is where you make both of them join in to one turbo flange of your choice. but i do not know how much clearance you will have up front with a stang.
it is all good. as long a you learn from your mistakes.
Old Jun 12, 2009 | 10:31 PM
alrght im just exploring all my options trying to figure out whats the best way to do this still havent decided on FI or NA i used to build alot of 5.0l's but thats a whole different ball game. whats a good turbo to use for this im only looking for low boost something with an internal wastegate would be nice and what size injectors would be good? also how well do the stock bottom ends handle boost?
Old Jun 12, 2009 | 10:32 PM
Originally Posted by 73 nova guy
same here
haha its definitely my new sig quote
Old Jun 12, 2009 | 10:35 PM
haha nice sig
Old Jun 12, 2009 | 10:53 PM
but wouldnt running both pipes into one turbo create alot of restriction? dont laugh at me im just wondering as i said ive never done something like this owuldnt you need a pretty large diameter turbo for that?
Old Jun 12, 2009 | 11:42 PM
Post
you could y a single turbo into your exhaust or just one big exhaust! but if your going to take on a conversion like that i think the exhaust will be the easy part. i would look around this forum a bit that will answer alot of your questions trust me!
Old Jun 13, 2009 | 10:25 AM
kbracing96's Avatar
1 into 2 cheap and easy....
Old Jun 14, 2009 | 03:19 PM
Rossko85's Avatar
model off of the LS4 front wheel drives man....we have two hearders that collect with a crossover pipe and then one single downpipe that comes out....there are some differences with the cars vs. trucks...like alum. block not iron and shorter crank shaft for the transverse mount etc...intake is so tiny on the alum block for the sedans, but we are getting ready to do a kit on mine....
