blower got crazy loud
Old Jun 22, 2009 | 08:40 PM
01boydws6's Avatar
Default blower got crazy loud
I just recentley installed a set of 60lb injectors and had my computer retuned, and I dont know if its just me or if my blower got way louder but after I installed the injectors I fired it up just to make sure everything was good to go and it seemed twice as loud idling as it did before, anything I should check?
O, mods are d1sc, 8lbs of boost, fmic, 60lb injectors, long tubes, ory, hooker cat back, tea 1.5 heads, ls6 intake..I have the vortech bybass valve.
Old Jun 22, 2009 | 08:49 PM
SilverSS's Avatar
Did you lower your idle?
Old Jun 22, 2009 | 09:41 PM
01boydws6's Avatar
nope, idle is the same.
Old Jun 23, 2009 | 12:48 AM
Got Me SOM's Avatar
a blower just doesn't get louder for the hell of it. make sure it's not bearing noise.
Old Jun 23, 2009 | 01:10 AM
Dewey's Avatar
i've got an idea... you need stronger pistons... lean out your fuel on stock pistons and you'll end up with a hole in them. saw that problem on a 05 dodge with a cummins tdi. if you want pics tell me, but otherwise i don't feel like looking for them. back to the topic, is your engine running rough, or just the increase in noise?
Old Jun 23, 2009 | 01:12 AM
Dewey's Avatar
another idea... its just human to feel like something is going wrong after you install anything, even if everything's fine. you just feel like you've messed something up any time you make a serious change to your fuel system, or anything for that matter.
Old Jun 23, 2009 | 03:42 AM
1dirtyZ's Avatar
check the intake hat on the blower or if any of the pipes blew off , that usually makes the blower noise more pronounced.
Old Jun 23, 2009 | 08:03 AM
viper9403's Avatar
Check for vacume leaks, that can cause a whistle sound
Old Jun 23, 2009 | 11:25 AM
01boydws6's Avatar
thanks guys I will take a look at the car tonight when I get home, I just wanted to get someone elses opinion, could all be in my head since its been a while since I drove the car just dont remember the whistling of being that loud
Old Jun 23, 2009 | 11:39 AM
'Trust''s Avatar
If some piping is leaking off air that is mostly like it, mine sounds awesome when it blows piping off, it just makes 5psi when it does, lol.
Old Jun 24, 2009 | 11:08 AM
Bad30th's Avatar
I'm interested in what you find on this, my P1SC has been loud as **** from day 1 but is still running strong 15k miles later...
One day when I find a pile of money sitting around I may send it in for service.
Rob (Bad30th)
Old Jun 24, 2009 | 11:23 AM
01boydws6's Avatar
I checked last night I didnt find any leaks, its seemed all the noise is coming directly from the bypass valve, it might be all in my head and that I havent drove the car in a few months...
Old Jun 24, 2009 | 09:14 PM
drew454u's Avatar
you might be suprised what soap and water will find, bubbles up nicely real useful when the pipes are ran low.
Old Jun 24, 2009 | 09:37 PM
01boydws6's Avatar
Ill give that a shot this weekend when I have some time, thnx again for all the help guys
