roots vs twin screw
Old Jun 30, 2009 | 01:12 PM
  #41
Killer_Z's Avatar
Hey jeff, werent u guys at Total performance working on a KB for the F-body? if so hows that working out? havnt seen n e updates.
Old Jun 30, 2009 | 01:24 PM
  #42
Mr. Sandog's Avatar
Is it possible that part of the issue is complete kits vs. hodgepodge parts, assembly, and tuning? The TVS 1900 on the CTS-V and the TVS 2300 on the ZR1 have the advantage of full OEM R&D and production. Magnuson also has complete kits (manifolds, H/E + intercoolers, injectors, tuning, etc.), whereas all that KB and Whipple do is sell you a compressor. You're on your own as far as fabbing up, choosing your injectors and tuning. This has to be a factor in the dearth of high-functioning screw setups.
Old Jun 30, 2009 | 01:27 PM
  #43
eb02z06's Avatar
What happened with Breecher and Stainless04Cal?
I have a couple of customers who keep asking me about the KB but I just don't know what to tell them yet.
Old Jun 30, 2009 | 01:42 PM
  #44
BLOWNBLUEZ06's Avatar
Originally Posted by Z06PSI
Well you have some facts mixed up because of what you have read on the boards. ..
Enlighten the forum on the mixed up facts.
Many of my facts come from the mouth of the nuts you swing from. The new "upgrade IAT" because the old one had a problem.
The inlet is a restriction for anyone that wants to make good power yet everyone is shown a 800rwhp dyno sheet thinking they can simply bolt this blower on a built 413 or 408 motor and make anywhere close to that.
Bring the truth. We all wanna hear it!
Whatever you have against Jeff is between you two and needs to stay off of the boards unless it was business done wrong and there are mitigations for it.
I have personal experience with the blower as I own one..
I have no problem with anyone that comes in here and tells the truth instead of a salesman or someone that reads a magazine and wants to speak with authority.
I have seen some respectable Cobras with the KB's under the hoods. Just not more than one large displacement Corvette and even that would have made much more with any decent power adder. That's a fact that can't be denied. I have also seen many people try and fail. I'm just hoping you're not one of them. Don't worry if you are though. There's still enough hype that someone might buy it from you. If your "trying new things" doesn't work out so well.
Bolt your heads on and show us the truth.
Old Jun 30, 2009 | 02:02 PM
  #45
DeltaT's Avatar
Originally Posted by slowscott
I was busy and then at Carlisle all weekend so couldn't respond. Glad you found the correct info yourself. I started this thread to learn something. I have no experience or biases with either kind of blower. The zr1 results are extremely impressive and I was curious as to whether the TVS had closed the gap between twin screw and roots or if the ls9 was just more bad *** than the ford motors.
I would like to see their dyno chart, because it seems a stretch for them to go from a Stage I = 680 at the crank to 740 at the wheels, but that's what the text post on their site says.
Jim
Old Jun 30, 2009 | 02:10 PM
  #46
Certainly more displacement in the LS9.
For the record and in case no one's seen it, Magnuson has a video of a Duttweiler built 434 with a small cam in it making 950hp at 15psi.
http://videos.streetfire.net/video/9...YNO_154043.htm
Old Jun 30, 2009 | 02:13 PM
  #47
viper9403's Avatar
Very respectable numbers! 150hp more then the highest reported KB and I bet its not tired from being completely maxed out!
Old Jun 30, 2009 | 03:00 PM
  #48
Z06PSI's Avatar
I am done arguing with you over this. As far as nutswinging I don't have a reason not to nutswing on Jeff as he has always been helpful and available. However the issues I have had lately are from a former forum vendor and you will not see me bash or even talk bad about them....ever because there are avenues for this and I am not some kid. Grow up
Because 1 car with an overspun blower (which I believe voids the warranty check with Kenne Bell directly for an accurate answer on this) and large displacement posted 800rwhp? Assumption - that it was overspun. This was an 15 psi run which I hit with a 3.5 top and 7.5 bottom
Why did Jeff post up a "fix" for the IAT issue if it wasn't broken in the first place? This is where you are wrong. I have been talking about the IAT movement and meth system integration as soon as I bought the blower 3 years ago from Jeff. Why 3 years? Part of that time I was in Afghanistan
Why is Jeff trying to work on an unchoked inlet if it isn't restricted in the existing design? How many belt designs, restrictor inlets, intercoolers, flip drive, brackets have the centri guys gone through?
rather than speak from personal experience? I think I do as stated..
Old Jun 30, 2009 | 03:01 PM
  #49
Z06PSI's Avatar
Engine dyno...I am arguing more for sport then anything else.
Old Jun 30, 2009 | 06:30 PM
  #50
02SSLE's Avatar
Originally Posted by Jeff@TotalPerformanceEng
IAT's... Again, anyone worth their salt in tuning knows that IAT's are DIRECTLY related to airflow and air compression. If your anemic on air, then you try to compress it, your temps WILL go up. This will be a non issue within the next 3 weeks. Although the IAT's will always be higher than other forms of F/I, they will be more than manageable. The member with 250* IAT's... The poster must have forgotten that the member had his damned cooling system ran backwards.. I have personally installed more KB's on LS platforms than anyone in the country, and I can say from first hand experience, we have NEVER had IAT's that high. Even in 117* ambient temps.
Also, there have been 800+rwhp KB LS vehicles for 3 years now. Its nothing new. But this is a debate that will continue until the new inlet is released. Until then, it is very difficult to make the power. But it has NOTHING to do with the blower itself.
I am the member that had the piece . I have never been so disappointed in a setup as I was that one. I did hook up the intercooler backwards. Joe at LMR figured it out right off because the other KB car he had done was the same way. I will tell you this I have a log file ht I am posting this happened 2 weekends ago. Proof is in the log file if you want I can post one of my maggie too. I am right in the effeminacy of this blower also. I am spinning it to 15psi 3 inch pulley. Here it is
Old Jun 30, 2009 | 06:58 PM
  #51
02SSLE's Avatar
This is also with Meth.
Old Jun 30, 2009 | 08:20 PM
  #52
02402RAMAIR's Avatar
Here is a Maggie track pass. IAT's are way lower than the KB.
Old Jun 30, 2009 | 08:37 PM
  #53
Z06PSI's Avatar
Track pass and dyno pass are two different things. I will post up a log file hopefully real soon with a dyno pass.
Old Jun 30, 2009 | 08:50 PM
  #54
02SSLE's Avatar
exactly. If eveyone wants to dyno race than I guess the KB's 180 degree temps are fine. The Maggie above is with a 2.9 pulley which makes 10psi on a stock LS6.
Old Jun 30, 2009 | 08:51 PM
  #55
Did you really just type that? So you're planning on your car being a dyno queen?
Boy are you in for a disappointment!
Old Jun 30, 2009 | 09:07 PM
  #56
Z06PSI's Avatar
Did I say dyno queen in there anywhere? Some people need to tune their cars...Now you are just being annoying..
Old Jul 1, 2009 | 06:18 AM
  #57
You're vacillating more than Hugh Heffner at bedtime. I thought they taught you to stay focused in the military.
Keep up would ya? You refuse accept a 950 engine dyno horsepower pull at 15psi, yet you're going to prove something to the readers on a dyno. You don't accept a real world IAT reading at on the track, yet you're going to show the readers your IAT logs off a short pull on the dyno to prove the IAT's are in line. That is what we call a dyno queen!
You say you have experience with this product because you own one, but haven't done anything with it but blow up your motor and let it sit for a year. Where's the logs from the blower on that motor? Where's any logs. Any track times? Where's Billy Mays when you need him? He could push this product and maybe have folks believing that it actually does what the manufacturer says, but eventually it's going to be time to put up or shut up. One thing I can say is after over "100k" has been spent on a car Jeff better put down some mid 8 second passes with ease, but you know where my money will be when it comes to betting time.
When my neighbors' A/C went out the other day, he said they were trying to sell him a heat pump. I couldn't for the life of me understand how a Kenne Bell had anything to do with his A/C.
Old Jul 1, 2009 | 07:44 AM
  #58
Old Jul 1, 2009 | 08:33 AM
  #59
viper9403's Avatar
Haha Brett your killing me!
Old Jul 1, 2009 | 09:32 AM
  #60
Z28usmc's Avatar
Originally Posted by 180ls1
Lol i never said roots were better you need to reread what i said. It is just unfair to compare a way overdriven roots charger to a twin screw that is the right size for the setup like you did.
The origonal poster asked if one was much better then the other. And you tried to give him proof by showing garbage for an example. Your second link you posted to "teach" me is good but still is not ideal because KB is going to post the results which will make their blower looks the best. If that test was done by a roots blower company the results on the two 1.5l blowers would have looked much different.
Get off your high horse and your problems that you have with roots blowers and try to help someone and give them honest feedback. That will help him get the best answer.
Just because you don't like my answer doesn't make it dishonest. I've HAD TWO roots style blowers- one on my Mach and one on my 03 Cobra. I loved them. And if medium range power is good enough for you they will suffice. However - for bigger HP MORE efficiently and you want a positive displacement blower then twin screw is the way to go. EVEN ROOTS MANUFACTURERS KNOW THIS- don't believe me?- ask THEM!! I posted several links one of which was to a supercharger site that sells ALL THREE types of blowers- once again I'm sorry that you didn't find that particularly helpful but THEY will also tell you that twin screws are superior and why. But of course they are biased too I suppose? Whatever bro. I'm not picking a fight, I'm stating facts- you're just arguing to argue- It figures.
