High Comp & Boost
Old Jun 25, 2009 | 08:46 PM
algws6's Avatar
Default High Comp & Boost
ok want to get off the juice and into some boost. the problem is im running 243 heads milled to 59 cc with a .045 gasket. the cam is not ideal (232/236 580 580 112+4) but i think it will do until i get a built long block. i was thinking of getting an A&A kit with a YSI and just run a big pulley, alot of meth, and a conservative tune. one thing i do have in my favor is DA, it goes from 4000' in the winter to 8000' in the summer. do you think it would be ok to shoot for around 600-650 rwhp without it being a ticking time bomb?
Old Jun 25, 2009 | 09:00 PM
BigRich954RR's Avatar
Whats your compression ratio ?
Old Jun 25, 2009 | 09:11 PM
algws6's Avatar
my calc. shows around 11.4 with .080 flycuts.
Old Jun 26, 2009 | 01:00 AM
Z28usmc's Avatar
Good question. I also have high CR- 11.3. I have been told by 3 tuners now that even with forged internals IF you go with a turbo or centri setup don't go much over 5-6 lbs of boost. More than that your engines longevity is in serious question.
Of course a buddy of mine is running 14 lbs through a twin .50 APS kit on his 11.1 06 GTO and has been doing so for about 10k miles with no serious issues.
Old Jun 26, 2009 | 01:12 AM
LS1Silverado05's Avatar
Its certainly been done... Meth is your friend...
Old Jun 26, 2009 | 09:57 AM
'Trust''s Avatar
I'd def. run meth on a higher CR motor.
Old Jun 26, 2009 | 11:02 AM
Rickys S/C Z28's Avatar
plus one
Old Jun 26, 2009 | 12:15 PM
SScam68's Avatar
That' should not be hard to achieve.
You can run some thicker gaskets to help drop the compression.
Old Jun 26, 2009 | 12:57 PM
Big_Bird_WS6's Avatar
pretty sure speed inc did a f-body with a 408 with 11:1 with an aps kit. with 7 lbs of boost they made like 700 plus horse. with the compression that high you dont need alot of boost to get high power numbers.
i am running a 10:1 motor. but i aslo am going e85.
Old Jun 26, 2009 | 03:45 PM
Z28usmc's Avatar
Like these?
http://www.cometic.com/domesticauto.aspx
I also heard you can run heads with a larger chamber but economically speaking it would be cheaper to just tear the engine down and run lower CR pistons.
Old Jun 26, 2009 | 05:55 PM
Louis's Avatar
Sig check! Id like it to be a 9:1 motor, but eh, eventually!
It will be a 95% C16 motor.... pump will be E85, or 2-5#s on 93 and a neutered timing table...
Old Jun 26, 2009 | 07:03 PM
algws6's Avatar
i tried calling and talking to you about this and a aps kit but the guy that answered the phone said you were to busy to talk. when i told him joking "ok....ill call a competitor" he hung up on me. kinda sucks too since your pops was so nice to me a few years ago when i was out there having godspeed tune my old ta back when the x2 hit the market. hell i even run the pros on my current Z06. anyway, i ended up buying some 317s to drop the compression.
Old Jun 26, 2009 | 07:04 PM
02SSLE's Avatar
I am about to do a TTIX build with a lS3 418 with 10.8cr. I have been low cr and didn't like it. Thought I would try this.
Old Jun 26, 2009 | 08:43 PM
sho-me speed's Avatar
Closed ex-Sponsor Account
Here is what I built.
https://ls1tech.com/forums/dynamomet...s-831rwhp.html
