POWER from a D1
Old Aug 24, 2009 | 09:32 AM
  #41
kp's Avatar
kp
Originally Posted by Rickys S/C Z28
for some reson i was thinking that the epp cam stopped making power at 6500 so that were we have been pulling my car to maybe that why its a turd?
I should have said shifted at 7000 and went through the traps at 7300. But I would occasionally shift it at 72-7300 and it really didnt make much difference. I'm sure the power fell off after 6600 or so but sometimes the less rpm drop between shifts will produce a better ET even though you shift well over peak power. Something you have to experiment with.
Old Aug 24, 2009 | 09:17 PM
  #42
Rickys S/C Z28's Avatar
that some good stuff there KP i think the next time i got to the track ill adjust my shift points and see if it helps thanks man
Old Aug 25, 2009 | 09:58 AM
  #43
Spade's Avatar
1998 Camaro Z28 w/104k miles
stock bottom end and heads with comp 918's
LS6 intake
3.9 pulley
3.5" twin intercoolers
LPE GT2-3 cam
stock M6
3.73's moser 12bolt
around 6.5psi w/belt slip
499 rwhp
489 rwtq
Old Aug 25, 2009 | 10:28 AM
  #44
airforcemanss's Avatar
^^im assuming stock fuel lines too?lol
edit: interesting kp ill keep that in mind for experimenting when the time comes. btw, what gearing?
Old Aug 25, 2009 | 10:40 AM
  #45
Spade's Avatar
Stock lines but with 50lb injectors and Walbro pump....
Old Sep 24, 2009 | 03:02 PM
  #46
so do you guys think it would be fine just to run a racetronix and hot wire kit on stock bottome end seeing 8psi or should i get a boost a pump too? plan on seeing 500rwhp and 60lb injectors
Old Sep 24, 2009 | 03:38 PM
  #47
LS1RedZ's Avatar
Yeah you should be fine with that. I maxed mine out on 7psi, but I have a built motor. But yeah it will be fine. I think its good to 550rwhp-600rwhp.
Old Sep 24, 2009 | 03:42 PM
  #48
Detoxx03's Avatar
I love this thread. Its very encouraging and gets me excited for when I start my new setup.
 Michael S. Palmer
Old Sep 24, 2009 | 03:54 PM
  #49
blue00ZZleeper's Avatar
x2 on that one!...
Current setup
stock bottom 346
P&P 241 heads
Motron 60's
Twin walbro 255's
M6
D1SC 9-10psi
Moser 9"
582-550 rwhp/tq
Meth soon to come...hope to break 600
Next setup
forged 347
317 heads
lots o boost lol
Old Sep 24, 2009 | 05:07 PM
  #50
mr_biscuitz's Avatar
Stock shortblock with stock heads
Ls6 intake
224 cam
full bolt-ons
fmic
60lb inj
two pumps
stock lines
stock rails
2 bar sd tune/ very conservative
d1sc pushing 12lbs
moser 12 bolt w/4.10's
m6
steel 3in driveshaft
spec 3+
makes right around 630rwhp and still has a heartbeat right now
Old Sep 24, 2009 | 07:22 PM
  #51
kp's Avatar
kp
I use a 3.70 with 28" tires, its pretty good all around gear to start with if you are making over 550hp with an auto.
Old Jan 28, 2010 | 11:46 PM
  #52
sixpack_2_go's Avatar
bringing back a great thread
Old Jan 29, 2010 | 12:49 AM
  #53
this must be a sign...ive bought a kit since this thread and im a few grand off from completeing but having money issues due to a move plus getting dishcarged. ive been holding out on selling it...
i just read though this thread again . i am going to take in account for what kp said when crossing the traps an letting her ride... im going with a 3.90 w/ 28 radials btw...kp. i came across a thread you were in on yellowbullet i believe (very informative) and i will be running a 275/60/15
bluesleeper, p&p 241 heads? isn't that still a 10.5 cr? i don't understand your setup that's in your sig.
Old Jan 29, 2010 | 03:31 AM
  #54
lol GOOD TO SEE THIS BACK UP!! i ended up running 10.51 with my D1 on a 26x11.5x15 @3875lbs.
Old Jan 29, 2010 | 06:29 PM
  #55
T/A KID's Avatar
What did you end up changing or doing different?? Nice time for a heavy pig, lol
Old Jan 29, 2010 | 08:59 PM
  #56
They were STOCK 853's lol. 10.1 is stock and thats where she was for awile. I now run 317's. The forged motor should be getting done soon.
Old Jan 29, 2010 | 09:34 PM
  #57
nothing yet have not made up my mind
Old Jan 29, 2010 | 10:02 PM
  #58
WHPLASH's Avatar
Originally Posted by dlandsvZ28
1998 Camaro Z28
347 H/C LS1 - stock bottom end
224/228/114 Cam
Mototron 60's
RaceTronix P & P
16 degrees timing -max
SD tune
Patriot L/C LQ9 heads
EPP FMIC - custom aluminum piping
D1SC
4.38 Pulley 8 rib
Performa 4LE60
Yank PY3400E
Moser 3.73 gears
8psi max @6200rpms
565 rwhp - Mustang dyno
With a little more timing could probably make 600 but NOT because of stock bottom end.
Damn, real close setup, but I'm still on the original twin 3.5" intercoolers and 6-rib. Performabuilt......good luck.
You 6-speeds put down some damn good numbers!!!
Old Jan 30, 2010 | 10:45 PM
  #59
tollway bandit 1's Avatar
HKE LS2
D1SC
Meth
Stock heads
3.4 upper pulley
8'' IW Crank
Twin intake 255s
60lbs injectors(need bigger)
817hp 702tq@ 18psi
Old Feb 1, 2010 | 08:21 AM
  #60
^^^^^^^^^^^^damn^^^^^^^^^^^^^^^
