POWER from a D1
Old Jun 28, 2009 | 01:07 AM
Rickys S/C Z28's Avatar
Default POWER from a D1
hay guys i am also most done with my car i was wanting to see how much power you are getting from your D1 set ups? please post:
what size engine you have
what is you compression ratio
what pulley sizes you are running
intercooler you are running
cam size
transmission
gears
boost number
im trying to see what i should hope for here thanks
Old Jun 28, 2009 | 02:22 AM
SilverSS's Avatar
My past set-ups.
2000 Camaro SS
383 Ls1
D1SC
9.7:1
7.65/3.55 Pulleys
Ebay FMIC 24X12X4
224/228/114 Cam, Stock 01 LS1, 98 LS1, 02 LS6 cams
M6
4.10 gears
16psi max @6800rpms
750rwhp (w/ stock '98 cam & 1.8 rockers) aggressive tune
2001 Camaro SS
346 LS1
D1SC
9:1 Comp
7.65/3.7 pulleys
Ebay FMIC 24X12X4
224/228/114 Cam
M6
4.10 Gears
13-14psi max @6600rpms
620rwhp
Edit: Exhaust - Pacesetter 1-3/4" headers and a TSP catted Y-pipe dumped before the axle.
Old Jun 28, 2009 | 02:28 AM
wow man great numbers!!
Old Jun 28, 2009 | 09:08 AM
4SFEDZ's Avatar
C5
TSP 402
230/240 591/608 115lsa
AFR 205's
D1SC with 4.63 pulley 4.5 psi
no meth
m6
3:42's (i think)
696 on a dynojet
Old Jun 28, 2009 | 10:38 AM
'Trust''s Avatar
My current setup on the D1-SC.
396ci.
9.62:1
7.65 and 3.4
4.5" ATI Twins
AFR 205's
224/232 .581/.585 115LSA
4L60E with Vig. Triple Disc
3.73's in Moser 12 bolt, 33 spline axles
18-19 PSI
773RWHP 709RWTQ - No dyno tricks, on the street wheels. Dynojet.
Old Jun 28, 2009 | 12:35 PM
wow guys y'all are making me happy!! i hope i get some were near what im seeing so far!!!
Old Jun 28, 2009 | 10:51 PM
Derek@BPP's Avatar
Please post your current setup
Old Jun 29, 2009 | 12:28 AM
9:8:1
6.0 heads (mostly stock except for clean up and milling after first motor popped)
EPP blower cam 232/240 .596/.608 115
EPP FMIC
7.25/3.7 & 3.4 not sure yet
4l80
3500 stall 3:73 in a 8.8
not sure how much boot it will make yet im trying to get it done this week
what do you think it will make?
 Michael S. Palmer
Old Jun 29, 2009 | 04:45 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=42
757 rwhp out of this T/A. Bob
Old Jun 29, 2009 | 08:32 AM
02 z/28's Avatar
hey ricky,what are you doing about the fuel system?
Old Jun 29, 2009 | 10:55 AM
LS1RedZ's Avatar
370 ci.
9.1:1
7.65/3.55
EPP FMIC
EPP cam 240/232
T-56
3:73s
11psi
Made 683rwhp @ 5800rpms with belt slip
Gonna see what she can do at 16psi before long.
Old Jun 29, 2009 | 10:57 AM
'Trust''s Avatar
I need to throw a 6 speed in mine and see what it would do!
Old Jun 29, 2009 | 11:45 AM
twin intake
Old Jun 30, 2009 | 05:26 PM
there has to be more D1 cars out there! post up you numbers!
Old Jun 30, 2009 | 06:08 PM
dlandsvZ28's Avatar
1998 Camaro Z28
347 H/C LS1 - stock bottom end
224/228/114 Cam
Mototron 60's
RaceTronix P & P
16 degrees timing -max
SD tune
Patriot L/C LQ9 heads
EPP FMIC - custom aluminum piping
D1SC
4.38 Pulley 8 rib
Performa 4LE60
Yank PY3400E
Moser 3.73 gears
8psi max @6200rpms
565 rwhp - Mustang dyno
With a little more timing could probably make 600 but NOT because of stock bottom end.
Old Jun 30, 2009 | 07:12 PM
Derek@BPP's Avatar
Very respectable numbers for street cars.
Old Jul 1, 2009 | 12:13 AM
yeah! i was hopeing to see if anyone was running an 80 also
Old Jul 1, 2009 | 10:23 AM
02NBMFormula's Avatar
what size engine you have: 347ci forged pistons, stock rods, ls6 heads
what is you compression ratio: 9.48:1
what pulley sizes you are running: 7.65 4.00
intercooler you are running: EPP FMIC
cam size: LS6
transmission: T56
gears:3.42
boost number: 10 or 11
584rwhp 532 rwtq on 93+meth on a safe tune
Old Jul 2, 2009 | 04:16 AM
keep it coming
Old Jul 2, 2009 | 06:38 AM
Shoulder Shaker's Avatar
396ci.
9.62:1
7.65 and 3.4
4.5" ATI Twins
AFR 205's
18-19 PSI
Wow those are some nice numbers. If you don't mine me asking what type of times have you run with this set up?
