Autometer boost gauges
Does anybody know if with Autometer boost gauges, same kind of style, electric Pro Comp Ultra Lite boost gauges,
I can get a new 30 psi reading gauge I will buy,
disconnect the remote sender's removable clip from the back of my current 20 psi reading gauge,
and connect it to the back of the 30 psi reading gauge's same slot in the back, not using the one supplied in the new one's box? That they use the same, compatible sender?
That way, it will be alot easier for me to swap gauges obviously without redoing all the wiring again.
Anybody know? Thanks!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
You said 20Psi is what you currently have? Autometer only shows a 15 psi or a 30 psi guage and each has it's own sender. So I'm guessing you have to go with the sender supplied with the 30 psi guage. Check out Autometers website.
So, yeah... I'm going to check their site again... I couldn't find info on their senders before.
Okay this is for the 4376, currently installed:
http://www.autometer.com/productPDF/0598A.pdf
Then, when you open the instructions for the 4377:
It's the same instructions...
I was thinking, the map sensor and sender can't be different designs can they? I'm hoping it's one design they fabricate that sends the same signal to the gauge. Then, depending on the gauge, either 15 or 30 psi, it displays the correct boost position with the appropriate needle position... Know what I mean? At least, I HOPE it's that way of course...
I guess I could call them (not today), but I thought I might check with you guys here first.
Autometer gives generic instructions for their guages. Looks like the sending units hook up the same but they are definitely different units for the 15 psi and the 30 psi guage. Hope this helps. Looks to me like all you need to do is swap sending units, not rewire everything. I run a mechanical boost guage so I don't have this issue.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
