LS7 w/11.5:1 Can I add a Procharger?
the only reason why i went with that low of CR is because i wanted a strictly pump gas/ high boost street motor.
Engine is not in yet. I wont be able to supercharge it until later this winter. I was/am hoping to run a high compression engine. Thats is why the low boost. Not ready to go with supercharger only engine
Dustin
Dustin
Well, if the motor is not in then you would need to address it as soon as possible. Since you will be running N/A for a while... you could, potentially, go to a 10.9 CR and still be funky n/a. However, with that CR, you should still be able to hit 700-800rwhp on pump with meth... maybe more... some guys are hitting 740rwhp+ with a stock bottom end LS7.
Good luck!
Good luck!
My only choices right now are stick with what I have, drop to 10.9 or 9.2. I am afraid if I go with the 9.2 it will be to doggy to even drive N/A. I may just have to wait until I can get it all purchased.
Why dont you just drive the NA engine until you really really want that boosted LSx and do a whole swap? Sell the NA motor and get a built boosted motor that will be ready to handle anything. Dont waste the hassle of having to baby an amazing motor just for a few pounds of boost. Do it right and you will be much more pleased with your results instead of fudging it to get where you want, only to realize a few months later, damn!, I want more boost but cant because my engine will blow if I raise it up...its just the nature of a car junky.....you willl want more.
Your D1-SC is MUCH too small for your motor, sell it and fund a F1-C/F1-R.
Shoot for the 9.2CR pistons, and mill the heads for ~9.6-9.7CR - run 15-20psi, make 900rwhp if you can hold the heads down. 1,000rwhp is you want to start to break things.
#33
This is too easy my friend:
I would consider a different ratio but I need lightweight pistons. That way I do not have to have it rebalanced.
Does anyone know of 4.130 bore pistons around 430 grams?
#34
I know what you are thinking. I got a good deal on the D-1. I plan to swap it later for a F1. Baby steps. The car has been stock for the last year. Just want to get something in it.
#36
why dont you just build the fuel system for E85 and run the high compression motor on 8-10psi? It would handle that like nothing, unless its not availible in your area, but in KS i would assume its plentiful. you should be able to max that D1 out on that car in the first pull or 2 and then you will have to replace it anyway. Go F1 or A&A YSi kit and you could do a solid 800whp on E85 with your high compression and not have to spend a dime on your motor
#37
