Dyno'd my 408 Camaro with TTi T76 Street Kit
#42
Working up a parts list now to start upgrading my build:
https://ls1tech.com/forums/forced-in...arts-list.html
Thinking about just putting on some new heads with dual springs since I'm still running stock 98 (307 casting?) heads.
#43
i dont think you where listening when people where telling you that the type of turbo kit you have will make allot of back pressure even more with an 88. but don't worry i have a solution for you. you know the logger manifold you have on the left side where the alternator used to be, get a shop to fab you another one, but for the right side. sell the 76mm turbo and get two smaller ones, depending on what you power goals are. and your back pressure issue will be solved to a point. but your ac will be gone
#44
you need to get a trans rebuild, new converter, heads, cam, valvetrain, intake, and a few other parts. Just because it's got two turbos and 408 cubes dosn't mean ****, with stock valve springs your gonna break somthing.
#45
Restricted User
Did you ever get the problem figured out???
check the link in my sig (go to the last few pages) and my dyno looks similar.....
I am in the process of buying a th400 to see if it was the tranny... although the tranny shifts fine and everything...
