Automatic vs. 6spd in the 1000 rwhp range
Bottom line is most classes put a penalty on stick cars... LSX shootout has a penalty on sticks this year. Autos can be lighter than sticks. Why is that?
Getting a stick car to leave like an auto takes lots of time and dedication, but once it is dialed in with the right clutch setup (clutch is key) there are actually several advantages to a stick over auto.
Here's me and LS2Formula playing around doing some gay roll racing. This is with my old LS2 408 w/ 380 shot progressive from a 40 roll (try that with a stick with 900 rwhp). The camera car is LS2Formula with a passenger obviously against me by myself. He had the weight handicap as his car was running consistant 8.9x in the 1/4. Both of these cars had the A/C in at the time, full stereo systems with subs and navigation. Power everything. Enjoy.
http://www.youtube.com/watch?v=InS4D5Cx0wE
Here's a real street race from a dig. Lots of prep was done to this road. I am in the outside lane leaving on a 100 shot and the tbrake and ramping in the rest of the spray over 3 seconds. The near lane is a twin turbo TA that had just run an 8.8 the previous weekend at a track rental in Bradenton FL.
http://www.youtube.com/watch?v=tj8NIHOPxMg
just like your car is a progressive nitrous. i would use my boost control to ramp in the boost from gear to gear.
On the flip side, I bet that with the proper stalled auto, your car would run atleast 3 tenths faster in the quarter mile.
I probably could shave off .3 with an auto cause my car has to be launched very soft to keep the tires happy. But I bet I can get .4 with a clutch change and face plated gears. That's my next step.
@ almost 800rwhp my car dead hooked @ 35mph up until 5000rpm,...quick speed shift into second,...dead hooked agian, and would stay that way when I was running a shitto drag radial on an 18" wheel. No boost by gear, no tcs,... NADA.
if not then would a manual hold jsut the same?
if you are not slipping that is just like a clutch(per say) and a gear is a gear. so if you arent slipping in stall. stick could/should do say thing
When I pushed in the gas pedal on that video from a roll, it's instant power and the converter would flash over 5500 RPM instantly. No stick car could hang with me at that power level from such a low roll (60 roll yes but not 40). They either got stretched by 2 cars right from the hit or would blow their tires off. V-series is aware of what the street racing scene in this area was like a year or so ago. His car is down right now I think but once it comes back, we can do some testing.
If it is a 'FUN' car raced only a little a stick is much higher on the 'FUN' factor scale.
but at the end of the day to each their own. you have fun woth your auto. and i will have fun with my stick
If you're board, go on you tube and search for snapoffracing or nitrousjamie. There are lots of videos of the local race scene. We have a bunch of guys and are pretty well organized. The street racing has died off since they opened the new track and relaxed the tech rules to get us off the street. No real point in risking street racing anymore.
I'm not going to read through all that, but I'll throw in my expereince. I was 6spd. and swapped to a 4l80. My car with the same boost as before, is way faster with the auto, even from a roll. You can imagine having to build rpm with the m6. With the auto, you stay right were you need to be, all the time.
I used to break spool the car with the m6. I would spool to 11-12 lb going down the road, and dump it. Even with boost built, its still slower than just flooring the auto, and letting the converter flash. Just ask the bikes around, and I'm not even on race gas. haha
I was a cry baby wuss about switching out my T56 for Th400. Could have saved myself a few thousand by listening to my friend sooner instead of wasting it on clutches.
True. But only in 1st gear,...2nd gear, zero spin. Also shifted as close to 6K or under due to my fuel starvation issue starting at 5500rpm. This is last setup,.. a real fuel system and upgrades in the works.
And for the record, you guys are, and have been some of the fastest LSX's in south florida,...not to mention probably the fastest stangs in SOFLA,..atleast on the street...where it counts. Hoping once we get these POS's squared away we can get some runs in with the cars. Heres my old dyno on the stock bottom. and 11psi, and 12degrees of timing
anybody want to do this in va?
the ONLY negative to my auto swap is that if you get to spinning, it is harder for me to pedal the car and salvage a run... but it is far outweighed.
