Automatic vs. 6spd in the 1000 rwhp range
"six speed lags cause of loss of traction" so autos dont spin? a 5000 stall in a auto is alot like a 5000 clutch drop with a stick if you know how to preload everything. at 1000 horse both will have launch problems with out the prefect set up. but we are talking about a 60 roll not a 0 launch. so this has no bearing on the subject. and if it did. i know a pretty good stick driver that can luanch good
"losing boost" ever heard of no lift shift? i can shift my car pretty damn fast. i wouldnt lift i would just stay in it. also the make boost controls that really help with this stuff.
The last trans died after hiting the limiter in OD. Started slipping on the way home and half way there it went all the way.
Not at 1000RWHP yet had Belt issues and still needs more tuning 3th post has DYNO graph but it all in the set up http://www.ls1gto.com/forums/showpos...71&postcount=3
For all out drag races autos will always be better. But for DD i will always like a 6speed better. I still get 21mpg highway.
(Again, both cars Turbo, 1000 rwhp, and hooking.60-160 mph roll)
As stated above trying to hook over 700RWHP on the street is hard at 1000RWHP neither is going to hook on the street
Stall speed varies with the amount of power you apply to the stall. BTW, I get 20MPG highway as well.
I think the M6 thing is more of a "fun" thing however.
I'm at 2600 rpms going 75mph so probably 2700 going 80mph. 28" tall tires.
I won the race, but with my PG i was spinning the whole time as well. The Supra was gaining, but couldn'y catch up in time. With the glide and my converter setup, it was instant boost and therefore I was able to jump out ahead a great bit, even while spinning. We both were making comparable power as well.
Far much cheaper than having to buy a twin disc and better T56, plus the better load on the turbo made the TH400 a no-brainer
Your dyno looks real flat because of how they compressed the HP column on the graph. But if you look at it as picking up almost 250 hp over the course of 1500RPM, it's not a real flat powerband.
