~Truck Manifold GT45 5.3 TransAm
Old 07-28-2009, 12:40 PM
pwrtrip75's Avatar
Default ~Truck Manifold GT45 5.3 TransAm
I had this whole 5.3 setup in my Nova the past couple years. Building a new setup for that so I decided to put this all in my TransAm.
~Stock untouched 5.3 shortblock
~317 heads
~224/224 .580/.580 112 cam
~60# mototrons
~MP GT45 Turbo set to run 15psi
~Ebay intercooler
~Tial 44mm WG & 50mm BOV
~Vic Jr intake (using their low profile elbow instead of the fabbed one I had)
~Griffin radiator robbed from the Nova
~ Stock electric fans
I have a million pics of everything. Heres a few.
Notched k-member
Theres actually 1/2" of clearance between the power steering pulley....picture makes it look like its touching.
Old 07-28-2009, 12:44 PM
NemeSS's Avatar
how is the lag with that turbo and 5.3?
Old 07-28-2009, 01:23 PM
pwrtrip75's Avatar
the 4000 stall makes up for some of it....and a 50 shot of spray. I also had 29.5" tires on it w/ 3.50 gears, The TA has 28" tires and 3.89 gears. Might help some.. It was kind of doggy off the line at the track.
Old 07-28-2009, 03:20 PM
GTP PWR's Avatar
whenever you get it out of the driveway let me know.. I can drop off my project! LMAO!
Look good!
Old 07-28-2009, 04:29 PM
Tiago's Avatar
looks good!
Old 07-28-2009, 05:01 PM
allthrotle's Avatar
Thats a very cool setup!
Old 07-28-2009, 08:23 PM
pwrtrip75's Avatar
Thanks,
Intake elbow showed up tonight. Edelbrock low profile one, got a good deal new/used on it so I didnt feel like making one. Also made the intercooler to throttle body pipe and got that on. Now im just waiting on v-band flanges, tial flanges, and 3.5" exhaust elbows.
Old 07-28-2009, 10:02 PM
blazin's Avatar
Looks real Nice.
Old 07-29-2009, 07:01 AM
forcd ind's Avatar
you do some great looking welding-i was trying to see how the truck mans.
were plumbed to a single, was thinking of switching to a turbo-i like the pipe setup to the turbo-did you mod. the truck mans., or just make up the pipe to the mans.-i have a stroker left over, was going to use it in my nova
Old 07-29-2009, 09:12 AM
pwrtrip75's Avatar
Thanks,
The manifolds are untouched.
Old 07-29-2009, 12:05 PM
Chevy406's Avatar
Two of the vehicles in your signature closely resemble what is in my garage ('99 FRC and a '69 Nova that will be eventually getting a turbo 6.0). I have a couple of questions for you regarding a turbo 6.0 in a Nova, but I'll start a new thread so as not to jack your build page.
Nice work on the Transam, and I look forward to seeing your '72 with the bigger engine.
Old 08-01-2009, 11:30 AM
Restricted User
1BAD_LS1's Avatar
Very nice! This is what im gonna bo doing shortly! Any chance you could mock up another hot-side pipe and sell it to me on the cheap??????? lol
is the notched K-member to get the manifolds to clear?
NICE BUILD MAN!
Old 08-01-2009, 11:35 AM
nastychevelle's Avatar
NICE BUILD MAN!
i think its to clear the downpipe
Old 08-01-2009, 12:53 PM
98Camarod's Avatar
NICE BUILD MAN!
lol whats wrong with your sts kit?
Old 08-01-2009, 04:51 PM
pwrtrip75's Avatar
NICE BUILD MAN!
The k-member needed to be notched to get the bolt in the flange. Studs wouldnt have worked. And stupid GM used SAE threads on the manifolds when the rest of the engine is metric. Threads are 3/8-16NC if you want to run a tap through to clean them out, I needed to.
Here are some pics of the notch to get the bolt in the flange on the passenger side.
I traced it in yellow
Old 08-02-2009, 03:15 PM
Restricted User
1BAD_LS1's Avatar
1) the lag kinda sucks (not bad though)
2) hate only one pipe out the back
3) Driving on wet roads scares me (dont wanna suck up all the water)
4)Oiling system sucks
I dont hate the sts kit i just think a frontmount would work alot better for my wants/needs.
Old 08-02-2009, 03:21 PM
Restricted User
1BAD_LS1's Avatar
So you ran a 3" or 3 1/2" downpipe over the k memeber?
Thanks for the pics!
Blaine
Old 08-03-2009, 04:52 PM
pwrtrip75's Avatar
Blaine
I havnt yet, im still working on it (waiting for the 3.5 elbows to get there). But yea im going to run a 3.5" DP. I'll post pics when i get it done.
Old 08-05-2009, 12:48 PM
Dr. Jeckel's Avatar
Few questions for ya. I am starting my front mount build and would like to keep the stock fans also. Did you put your turbo up higher out of necessity or asthetics?
I plan to run a t-76 and was wondering if you though it might fit down lower in the middle?
Did you have to notch the frame because you are using 3.5", because I believe 3" should work...shouldn't it?
Last one, Where are you supporting the Turbo from?
Thanks for the help, James.
Old 08-05-2009, 07:46 PM
pwrtrip75's Avatar
Yes it is mounted up high because it wouldnt fit down any farther. I have a VFN WS6 hood so hood clearance is not an issue. I like the fact is is mounted high also because of oil drain back, and nothing to do with asthetics, but it dont look too bad sticking out there.
I notched the frame before I put the kmember back in just in case. The outlet on the turbo is 3.5", I dont want to reduce it.
Turbo is supported right now from the piping, it is pretty heavy duty stuff, but I plan on adding some brackets from the engine somewhere, havnt got there yet. It all needs to come off to put the wastegate on, whenever my 3.5" elbows get here.
Quick Reply: ~Truck Manifold GT45 5.3 TransAm
