help car wont start!!!! need help!!!
it just keeps turning over its building a little bit of oil pressure and it would back fire ever so often.my battery was dead so i was trying to start it off of a batt. charger in jump mode but i dont think thatd be the problem the car had plenty of juice
also it has a versa fueler and 96# injectors which i wish i never got but im stuck with them now it has a aeromotive fuel pressure regulator that i tried setting all over from 35 up to 50 it never helped seemed like it wanted to start with it higher like 45ish but still nothing i pulled a plug and it was dry as a bone
the fuel system is dual walbros aeromotive rails -8 feed -6 return and yes it has gas lol
right now its on a brief tune by nick williams just so i can get it checked for leaks and stuff before i go get it tuned but i cant check for leaks if i cant start it lol
please help any suggestions would be great
thanks!!
thanks guys!!
I duno I'm so mad at it
Also Williams performance told me to leave the fuel at 35 psi since that was where nick tuned it at should I up it to 60 just to try it?
Thanks guys!
Anyone else got any experiance or suggestions?
Please! I'm open to any thing except ether lol
I am not sure of the procedure to check for spark with these coil packs. I always pulled a wire and stuck a spare plug in it and placed it close to some metal with distributor setups. When you crank it, you should get a good spark from plug to metal. But these are real basic compared to data scans. Good luck
Thanks tho
Thanks!
Stupid question but what would that do if its bad? It was working before I tore the car down for the build. I mean the car started and ran great its been down for about 4 months so its very possible.
Thanks!
