Progress pics of my MPT76 Front Mount 01 SS.
Old Sep 24, 2009 | 07:30 AM
  #81
Vcious04's Avatar
Originally Posted by Reject
damn you got my rims too
Love 'em right!
Yeah, maybe shoot for 16psi. I think I will be pretty happy even with 600rwhp for now. Should find out soon!
Originally Posted by davidadavila
i want to see those numbers man
I will keep you posted!
Originally Posted by 1badWS6
Looks sick dude! Can't wait to see what this thing puts down! When do you plan on taking it to the track?
Thanks man! Me too, should find out this saturday is all goes well. I plan on going to the local dfwstangs/lsi cruise 10/04/09 and make a few shakedown passes.
Originally Posted by boostnificent
looks good man. what suspension parts do you have?
Thanks! Stock suspension front to back with modified stock springs.
Originally Posted by FATZ28
SLOW!!!!!
Brad, you might just be grounded from getting a ride. UNLESS, you are correct.
Old Sep 24, 2009 | 11:05 AM
  #82
FatZ28's Avatar
Haha you know I'm joking bud. Hows the tuning going?
Old Sep 24, 2009 | 12:14 PM
  #83
Vcious04's Avatar
Lol! It's going pretty good. He's doing some SD street tuning now and also performing cold start tuning and such. I'll give you a shout later on.
Old Sep 27, 2009 | 09:03 PM
  #84
boostnificent's Avatar
did you get to run it on the dyno Sat.?
Old Sep 27, 2009 | 09:12 PM
  #85
Vcious04's Avatar
Unfortunately not. Friday night he attempted to perform some mild dyno tuning but made 10psi between 2900-3200rpm almost instantly. Trying to get that figured out so he can properly tune it.
Should have some dyno #'s hopefully within the next few days. He did say the boost hits hard tho.
Old Sep 28, 2009 | 07:42 AM
  #86
Super Slow SS's Avatar
I don't see what that problem is?
Old Sep 28, 2009 | 07:05 PM
  #87
kmracer's Avatar
too much boost for an inital tune. he'd probably want it around 5-6 psi, then move up from there.
Old Sep 28, 2009 | 09:30 PM
  #88
Vcious04's Avatar
+1.
Just getting a little frustrated with the waiting game. Tuner has been real busy with other vehicle's which is delaying to process completion on mine.
I did talk to them today and asked if he could go ahead and tune on 10lbs, but evedently what is happening is the wategate doesn't seem to be functioning (which is baffle'ing, because it's mechanical??) which is allowing turbo to pretty much boost whatever it wants.
I'll keep ya'll posted.
Old Sep 28, 2009 | 10:04 PM
  #89
Reject's Avatar
what i did when i took it to SQR (super quick turn around time and awsome deal btw) is i let them tune it at the WG spring, and from there once i had that area tuned i started to tune it to the max (14.5) just needed to get a good starting baseline to play with
Old Sep 30, 2009 | 05:04 PM
  #90
Vcious04's Avatar
Pretty excited!!
Figured out that the JGS wastegate was shipped with the wrong spring (12lb spring).
Tuner called me with some info on some early dyno results.
1st Pull, 14 deg timing, 11.6 AFR, 5psi, 4k Max Pull
415rwhp @ 4000rpm
rwtq unkown
2nd Pull, 14 Deg Timing, 11.6 AFR, 5psi (boost creep to about 7psi by 6krpm), 6k Max Pull
520rwhp
490rwtq
This was also dyno'd with my 4.10 gears still installed.
He will be doing some more tuning tomarrow, adding some timing and boost and should hit 600rwhp no prob on 10psi!!!!
Guess my home made junk worked!!!
Should be picking it up tomarrow after work, I'll keep ya'll posted on more dyno results!
Old Sep 30, 2009 | 05:22 PM
  #91
Dr. Jeckel's Avatar
Looks very promising.
Old Sep 30, 2009 | 06:39 PM
  #92
kmracer's Avatar
what wastegate is that? 50mm?
Old Sep 30, 2009 | 07:07 PM
  #93
Reject's Avatar
good numbers, those little 76's put up some quick spools.
Old Sep 30, 2009 | 07:25 PM
  #94
Vcious04's Avatar
44mm JGS
Old Sep 30, 2009 | 07:33 PM
  #95
FatZ28's Avatar
Bring it to town playa!!!!!
Old Sep 30, 2009 | 07:57 PM
  #96
1BAD_LS1's Avatar
Restricted User
Hell ya... awesome numbers for low psi and gearing! GOOD WORK!
Old Sep 30, 2009 | 08:04 PM
  #97
Vcious04's Avatar
You know it Brad!
Thanks bro!!!
Man, I am stoked! Even as it sits now it making 100rwhp/120rwtq more than I was making n/a. It's always a good feeling after building something it actually works decent. I am going to talk to him tomarrow and see if I can talk him into a 15psi pull.
I will keep ya'll updated tomarrow with more dyno results.
Old Sep 30, 2009 | 08:20 PM
  #98
1BAD_LS1's Avatar
Restricted User
You know it Brad!
Thanks bro!!!
ya see if he'll do a 15 psi pull just to see! lol I just wouldn't push the stock ls1 shortblock that hard to long! Mine died at 9psi after a while (but my compression was way high and cam was a horrible cam for boost, I killed #7 piston ringland).
My bet is 780hp at 15psi, lol.
forgot to ask are you running a single walbro? or dual? I read 550 is MAX on a single walbro......
Old Sep 30, 2009 | 09:02 PM
  #99
Vcious04's Avatar
Yeah, I've heard of running 15psi with a stock lq4 since the compression is lower than ls1/lq9. Just curious what it will do, but he will probably be leary to try it. But I for sure will get a good 10-12psi pull.
Single Racetronix pump with hotwire kit.
Old Sep 30, 2009 | 09:36 PM
  #100
bad6as's Avatar
your gonna need more pump over 600 for sure
