Progress pics of my MPT76 Front Mount 01 SS.
Old Sep 10, 2009 | 06:20 PM
  #61
bad6as's Avatar
power goals?
Old Sep 11, 2009 | 02:41 AM
  #62
TX RED's Avatar
I would like to know if u are having any problems with stock radiator
Old Sep 11, 2009 | 07:26 AM
  #63
FatZ28's Avatar
I posted in your other thread but I don't know if you saw it. Car is sweet Jeremy!!!!! Let me know when you come to town so I can see that bad boy.
Old Sep 11, 2009 | 09:07 AM
  #64
LS1Formulation's Avatar
Just curious what kind of investment you've made so far. Looks like you've done a great job, I'm probably going to copy your design a bit, if that's ok.
Old Sep 11, 2009 | 09:31 AM
  #65
Vcious04's Avatar
Originally Posted by Super Slow SS
not worried about overheating with the stock radiator stood straight up, I thought it wasn't made to do that and water would not stay in it long enough to cool? You will have to keep us posted on how it does.
No problems at all. I ran a stock LS1 radiator in my old LS1 coupe with the same fan (strait up) and it never saw 210 on a hot day, even with the trans cooler roated to the radiator.
Originally Posted by bad6as
power goals?
600ish on 8-10lbs, 700ish on 15lbs (if it holds, if not, time to build a forged bottom end)
Sup Brad!! Yeah, hopefully I can get it fully tuned tomarrow at RPM. Plan on loading up and leaving early. I'll call you when it's done tuned! BTW, it's sounds so badass with the cam through the open 4" downpipe. Sounds very similiar to my old true duals dumped, but much hollower with a turbo whistle.
Old Sep 11, 2009 | 11:27 AM
  #66
WhiteWind's Avatar
jerm man!!! Hey call me when that bad boy is done wanna know your dyno numbers. Might have to fly home see it. Later bro!!!
Old Sep 11, 2009 | 12:15 PM
  #67
JAX04's Avatar
judging by the parts and money u spent, you came out very very well with this setup. congrats, i cant wait to see some numbers
Old Sep 20, 2009 | 11:31 AM
  #68
Vcious04's Avatar
Well, found out Friday from my tuner that the turbo is not draining properly allowing oil to backup in the turbo causing oil to leak past the seal and into the downpipe. Just wanted to let the ones know that are in the process of building a lower front mount setup on a budget a scavenger pump is likely needed. Not too much $$ extra, but extra none the less.
The pump I chose is the 12VDC Version:TurboWerx Part # TWX-300-12V (About $450 to install and dial in). Having them install that along with a Turbonetics manual boost controller. Main reason I went with the top of the line version, the entry level pump will not be available for 10-15 days. I want this thing done, only cost additional $100 and is suppost to be much better.
Oh well, I was planning on having it all tuned and dyno'd tomarrow, but I want to make sure it's all good.
To be continued!!
Old Sep 20, 2009 | 11:37 AM
  #69
Vcious04's Avatar
Thanks!
Old Sep 21, 2009 | 08:05 PM
  #70
IKnowtheFuture's Avatar
awesome i cant wait til i put a turbo on mine
Old Sep 22, 2009 | 09:57 PM
  #71
boostnificent's Avatar
how did the dyno session go?
Old Sep 22, 2009 | 10:13 PM
  #72
Vcious04's Avatar
Still waiting on the scavenger pump to be installed. If all goes well this saturday I will find out.
Starting at 6psi and plan on upping it to 15psi if it holds.
Old Sep 23, 2009 | 12:01 AM
  #73
sweet. i am curious to see what kind of numbers you throw down. i have a 76mm as well and an opporitunity to buy a 6.0 for a decent price.
Old Sep 23, 2009 | 09:40 PM
  #74
Vcious04's Avatar
Lol, I forgot to post pics of my SS loaded up on the trailer headed to my tuner last week.
Talked to my tuner today and all is going well and should be finished by friday so we can get some pulls on saturday. Yeah!!
Old Sep 23, 2009 | 09:46 PM
  #75
Reject's Avatar
damn you got my rims too
Old Sep 23, 2009 | 09:57 PM
  #76
Reject's Avatar
it'll hold to 16# on the 76mm
Old Sep 23, 2009 | 10:10 PM
  #77
davidadavila's Avatar
i want to see those numbers man
Old Sep 23, 2009 | 10:12 PM
  #78
1badWS6's Avatar
Looks sick dude! Can't wait to see what this thing puts down! When do you plan on taking it to the track?
Old Sep 23, 2009 | 11:11 PM
  #79
looks good man. what suspension parts do you have?
Old Sep 24, 2009 | 06:19 AM
  #80
FatZ28's Avatar
SLOW!!!!!!
