Check This Out......
Old Aug 2, 2009 | 10:17 PM
sho-me speed's Avatar
Closed ex-Sponsor Account
Default Check This Out......
Blown Head Gasket caused this. Here is a pic of the cylinder. This motor blew a head gasket.
The question is: can this block be run as-is with some light de-burring or will it need to be decked. The heads are being re-surfaced as we type and new head gaskets with copper spray are set to go on also. The motor will see roughly 12-16lbs of boost.
Old Aug 3, 2009 | 07:41 PM
OUTLAWZ RACING's Avatar
I am far from a builder but if he surface is smooth ,even and within spec I dont see a problem.
Old Aug 3, 2009 | 09:30 PM
I have spoke with a few builders who say Hylomar blue around the fire ring and it should be good. Any other opinions??
Old Aug 3, 2009 | 09:38 PM
elias_799's Avatar
i would deck the block for sure, you want the surface to be completely smooth, especially with FI
and why are you not using dexcool ?
Old Aug 4, 2009 | 08:45 AM
KWIKKAR's Avatar
Dexcool is **** for coolant..
It will actually eat the inside of the motor apart. Do you google search.. U should switch to the green stuff.
Old Aug 4, 2009 | 11:30 AM
BigRich954RR's Avatar
I would deck the block worth it in the long run
Old Aug 5, 2009 | 10:00 AM
I haven't run Dexcool in years. Way too many problems with it that I have heard of.
Old Aug 5, 2009 | 11:19 AM
HUNTER02SS's Avatar
You got lucky. I have seen blocks that were garbage after a blown headgasket. looks like you cut it with a plasma cutter they were so bad.
Old Aug 5, 2009 | 12:13 PM
Big_Bird_WS6's Avatar
this is right.
i had my blcok sleeved by erl. darton(sleeve company) recommends EVANS coolant
