boost results and how to increase?
Old Aug 7, 2009 | 05:02 PM
JC70SS's Avatar
Default boost results and how to increase?
Well my car was dynoed Sunday and it was a few hp shy of 500 at the wheels. I was told by a few various people that my 6" crank pulley and 3.85" blower pulley would get 7-8lbs. This is a 6 rib P1SC set up with hooker headers and stock heads and an MTI R1 cam on a 116lsa. So with having built a forged motor, what combo next spring do I go to to get 8-10 lbs of boost?
Old Aug 8, 2009 | 01:26 AM
Jimmy P's Avatar
If you are having the motor built, I would suggest you upgrade to the D1SC with a 8 rib setup and go for 16psi .
Old Aug 8, 2009 | 04:56 AM
JC70SS's Avatar
It is already built and installed and dynoed. A P1SC is fully capable of making me 8-10 lbs of boost, how do I get there?
Old Aug 8, 2009 | 08:44 AM
AFASTYZFR1's Avatar
8-rib set up and pulley it to max out blower
Old Aug 8, 2009 | 11:23 AM
JC70SS's Avatar
I am not switching to an 8 rib set-up. I can make that with the correct pulley set-up which I am looking for info on.
Old Aug 8, 2009 | 01:06 PM
Jimmy P's Avatar
You will have to have it retuned, possibly on a dyno if you add more boost to it.
Old Aug 8, 2009 | 02:48 PM
JC70SS's Avatar
yes I realize it will need a re-tune, I also need 60# injectors. Should I get a 3.20 pulley or a bigger crank pulley?
Old Aug 8, 2009 | 03:38 PM
AFASTYZFR1's Avatar
belt will slip with 6-rib
AFASTYZFR1's Avatar
Bigger crank pulley would be better.....might slip less
