Fastest stock short block 1/4 mile pass.
Old 08-08-2009, 01:23 PM
tirefryin_s10's Avatar
Default Fastest stock short block 1/4 mile pass.
I know guys have pushed these things into the high 5's in the 1/8 but what I wanan know is what is the fastest anyone has gone in the 1/4 and had one live?
So far I am at 9.51@146 and corrected to sea level that would be 9.41@147.4
that was on 14 psi and pump gas, I drive the car to and from the track and to work and back all the time.
Just kinda curious how fast guys have went on this junk.
Old 08-08-2009, 01:36 PM
Sweet71's Avatar
Dont you mean long block?
Old 08-08-2009, 03:53 PM
black98ws6ta's Avatar
I would like to know some more info on the fastest stock short/longblock car's out there. How many passes they held up as well.
Old 08-08-2009, 04:23 PM
5_02ls1's Avatar
me too....
Old 08-08-2009, 09:35 PM
kp
kp's Avatar
You would be the one of the fastest on a stock short block I think, Parish had the turbo fairmont with a stock 5.3 (just had a cam and valve springs if i remember) and the Ohio boys went pretty quick with an incon TT on a stock short block - dont remember the exact ETs though.
Old 08-08-2009, 09:38 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm thinking 9.40 for Mike Brown in the CE TA with Incon TT setup I could be wrong.
Old 08-08-2009, 10:15 PM
kp
kp's Avatar
I think Mike went 9.85 or something, that was back in 2003. I'm pretty sure Parish ran 9.49 with the fairmont and the 5.3.
I could be wrong too..
Old 08-08-2009, 10:49 PM
extremetoy's Avatar
curious what the race weight is and what trans and stall are you running?
thanks, Gary
Old 08-09-2009, 01:22 AM
race weight is right around 3250-3300 and I just put in a new 9.5" PTC Custom.
I think parish is the fastest with a 9.49..... I am gunning for a 9.40!
Old 08-09-2009, 10:05 AM
MY99TAWS6's Avatar
How the hell can you keep a stock engine alive at 14psi when seen many many blow ringlands out at way less boost some at 8psi ? That is a miracle for sure. Excellent results.
Old 08-09-2009, 12:41 PM
02SSLE's Avatar
Tuner is everything and hard to find a good one.
Old 08-09-2009, 12:46 PM
Grr
Grr's Avatar
dont see whats so hard, i ran my stock LQ4 at 16psi for 2 months of DD duty and about 70 1/4 mile pulls, on 91 octane too
Old 08-09-2009, 02:42 PM
Anymore info on how fast it went? What power it made? ect?
Old 08-09-2009, 04:46 PM
Badass94z's Avatar
What are your 1/8th mile time slip looking like on that pass, i have been 5.80's with mine in the 1/8th 120mph i am getting readdy to run in the 1/4th
Stock LQ4 with a single turbo
Old 08-09-2009, 05:02 PM
Restricted User
98Z28CobraKiller's Avatar
That's good for a 9.0 @ 150. Are you on stock short block or long block?
Old 08-09-2009, 05:21 PM
Grr
Grr's Avatar
on 12psi the first year with a stock 4l80 converter (around 1700stall) and street tires it did 12.20@124
On DRs and 8-9psi it did 11.7x@118
stock stall and 14psi it did 11.7x@127 (i was extremely hungover and couldnt brake boost)
with a fuddle 3200stall, DRs and 8-9psi it did 11.42@119, every one of those runs was 3760 raceweight and on 89 octane, no intercooler. According to my logs it was making 632hp and 585tq. Accurate or not the HPT horsepower calculator is consistant. On 16lbs, 16* timing, 91 octane and 3 gallons of 105, no intercooler it was making 785hp and 690tq (these are all at the crank) and i could pull cars that trapped 135-140 on the interstate by a car or 2. Im pretty confident it would have ran bottom 10s at 135, i had a handful of passes that were 127-132 on 14lbs and just 91 octane with 12* timing. According to the logs again, from 14lb/12* up to 16lb/16* i picked up 80hp. This was in a 87 Buick GN with stock LQ4, Lunati 224/224-112 cam and a BW S475 as the only mods to it. Also with a 9" and 3.08 gears
Old 08-09-2009, 05:28 PM
Restricted User
I'm sure someone has gone 8's on a stock short block.........atleast once.
Old 08-10-2009, 12:31 AM
I have been 6.1@117 1/8 mile numerous times but the hard part is to make them live for a long time and lots of 1/4 mile runs and lots of daily driver duty.
Guys have been 5.7x in the 1/8 but try to make that same set up live for numerous full 1/4 mile pases and see how it works out.
Old 08-10-2009, 10:22 AM
LS1Tech Co-Founder
I don't think anyone has gone 8's with a stock shortblock but it's doable.
Old 08-10-2009, 12:59 PM
I would like to know.... not like I get anything but it would be cool to know.
Quick Reply: Fastest stock short block 1/4 mile pass.
