what balancer do i need for a d1sc?
Old Aug 20, 2009 | 09:25 PM
Taubr Unit's Avatar
Default what balancer do i need for a d1sc?
i see theres one specific for supercharged engines, whats so special about that one? Basically i need a ati balancer that i can bolt up the procharger pully to. Can i buy this one ( http://www.summitracing.com/parts/ATI-917277/ ) since i dont have a/c? Will the procharger pully mount to it? And if i buy this one will i still need to buy a hub?
Old Aug 21, 2009 | 04:59 AM
EPP's Avatar
EPP
The 917277 does not have the holes drilled for the blower pulley. The holes can be drilled, we've done it many of times. Here is the balancer that comes ready for the ProCharger pulley to bolt on to it. http://www.exoticperformanceplus.com...html?item=1899 Bob
Old Aug 22, 2009 | 04:14 PM
Taubr Unit's Avatar
anyone else have some experiance?
Old Aug 22, 2009 | 08:42 PM
T/A KID's Avatar
I run the ATI superdamper
Old Aug 22, 2009 | 08:57 PM
kp's Avatar
kp
You can use any of the LS1 ATI dampers as far as I know unless you have a/c. If you have A/C you run into problems with the newer ones not having the 6 holes like the older dampers have.
I am using the 917277 damper on mine with an SDCE drive pulley, it just used three bolts and I'm pretty sure the procharger pulley uses three as well but Bob would know better than anyone.
The 917277 comes with a steel hub, which is what you want.
Old Aug 22, 2009 | 11:35 PM
Taubr Unit's Avatar
the procharger pully bolts on with 3 bolts also. So you didnt have to drill out more holes and tap them etc. on the 917277? If so then for $360, thats a damn deal and i can order it right now as opposed to $500 for the "blower" specific one.
Old Aug 23, 2009 | 12:03 AM
kp's Avatar
kp
I only use three bolts, not sure why that 6 bolt one is so expensive unless it comes with the A/C pulley.
Old Aug 23, 2009 | 11:27 PM
airforcemanss's Avatar
i don't understand what with the purpose of more bolt holes or older version vs new??
what ones are use for us that still want AC?
Old Aug 24, 2009 | 06:54 AM
BIG_MIKE2005's Avatar
The one I recently bought in the sale section is a older model with the (6) torks bolts holding the outter dampener to the center hub assembly. And the actual hub itself seems to be machined with the A/C pulley on the back side of the main dampener. It also only has (3) holes for the blower pulley to bolt to the face with.
Hope this helps.
Old Aug 24, 2009 | 07:34 PM
Taubr Unit's Avatar
ok now one more question before i buy, since i have a 6.0 am i gonna have spacing issues with the 917277 or its gonna fit just like any ls1 motor?
Old Aug 24, 2009 | 07:44 PM
kp's Avatar
kp
I have a 6.0 crank in my 347 so I assume it will work.
Old Aug 24, 2009 | 07:46 PM
Taubr Unit's Avatar
cool, good enough for me. gonna order it right now.
