TR230/224 good turbo cam?
Old 11-27-2003 | 09:37 PM
10secondZ's Avatar
Default TR230/224 good turbo cam?
Hello,
It seems to me that the TR230 reverse split on a 114 LSA would be a great turbo cam...but I have not seen the cam card one one before...is there too much overlap or should it hold good boost?..if anyone is running this cam please post up and tell me how ya like it or if anyone knows if it will be good for a turbo motor...Thank's,
Carter
Old 11-27-2003 | 09:40 PM
jrp's Avatar
jrp
SN95 Director
i believe you'd want a traditional split cam (more exhuast duration), plus with the 111lsa you'll bleed off all the boost. consider a 115+ lsa.
Old 11-27-2003 | 10:57 PM
Speedfreaks101's Avatar
I am also interested to see what the turbo experts say.....
Old 11-27-2003 | 11:08 PM
10secondZ's Avatar
Originally Posted by jrp
i believe you'd want a traditional split cam (more exhuast duration), plus with the 111lsa you'll bleed off all the boost. consider a 15+ lsa.
Turbo's like more intake duration than exhaust..supercharger's like traditional splits.....Do they make the TR230 on a 114 or 116? or i might have it custom ground if not...the 111 lsa is way too much...does anyone run this cam or something similar? Thank's,
Carter
Old 11-28-2003 | 12:26 AM
eviltwins's Avatar
Correct, turbos do like more intake duration than exhaust.
FWIW, my cammotion solid roller is 238/232 @ .050, .639/.627 lift W/1.7's, .010 hot lash intake and exhaust. Works great, has some thump at idle, and makes plenty of power.
Old 11-28-2003 | 12:50 AM
10secondZ's Avatar
What LSA is that on? and does it bleed off boost or does it hold steady?..Thank's,
Carter
Old 11-28-2003 | 12:57 AM
Whistler's Avatar
Sawzall and Welder Mod
FWIW, I put a 224/220 on a 115 LSA in the new turbo engine. Turbos dont need a huge cam to make big power.
Old 11-28-2003 | 01:17 AM
qqwqeqwrqwqtq's Avatar
Carter
The cam will not 'bleed off boost', therefore limiting boost. Boost pressure is controlled solely by wastegate/boost controller settings.
That term is often used in supercharged applications, because too much overlap and you will end up exhausting some of your intake charge.
On most turbo systems, exhaust pressure is higher than intake pressure. Reversion will occur during overlap.
What are the details of your combination, and what are your goals for HP and at what fuel octane, RPM capability, and driveability.
Old 11-28-2003 | 04:43 PM
eviltwins's Avatar
Carter
Cam is 115 LSA, boost is sold as a rock from 3300-6800.
Old 11-28-2003 | 07:12 PM
cfi_luz's Avatar
I am needing to select a turbo cam too and would appreciate any help
Old 11-30-2003 | 11:44 AM
mongse's Avatar
I ruin the end of films...
All the info you need is posted above...
more intake duration that exhaust
no need for a monster cam (large lift/duration)
114/115 LSA
Reverse split good, traditional split bad for turbos
Very good starting point for a turbo cam.
Quick Reply: TR230/224 good turbo cam?
