Any manifolds that allow factory location of Alt. On LS2??
Im going to be getting everything started as far as ordering parts for my LS2 350z turbo build and was wondering if there were any manifolds ie: truck? C6? that allow you to keep the alternator in the factory location(under the PS pump). I don't have A/C becuase I plan on running the DP somewhere over there....any suggestions?
I just bid on a set of LS3 C6 manifolds....they look like they should work perfectly for my setup. Hopefully ill have enough room on the passenger side to fit a 4" DP.
the GXP manifold is low and sleek. and also the escalade manifolds, there is a GTO build over on LS1gto that is using escalade manifolds upside down and forward. they seem to be pretty low profile. atleast under the low hood of the 04 gto. hope this helps
http://www.ls1gto.com/forums/showthread.php?t=327694
