Is a PTE-70 the right size for LS1?
Old Dec 2, 2003 | 11:00 PM
Revelation222's Avatar
Default Is a PTE-70 the right size for LS1?
It's a PTE-70, P-trim, .81 a/r
Would this turbo be a good choice on a stock bottom end 346ci ?
Also, is there a basic turbo write up online for turbo illiterate people such as myself? (For sizes, trims, boost ranges, etc.)
Thanks in advance.
Old Dec 2, 2003 | 11:30 PM
RICE ETR's Avatar
Turbo Addict
the .81 might be a little too small for the Ls1... good for spool up but will choke a little topend. Though a tangential exhaust housing will noticeably help things.
I am sure others will respond on this.
And even though it is mustang based.... http://www.turbomustangs.com/ has a ton of info.
Go to "main site" then "links"
Also "Maximum boost" is a great book.
Old Dec 3, 2003 | 11:10 AM
MYTURBOT/A's Avatar
I think that turbo would work good for a stock ls1 @8-9psi and when you get good internals it`ll still work decent at 12psi. good turbo to grow with IMO. The .81 A/R will be a little slower spool and better top end Not the other way around. Probly spool around 3100-3200rpm On stock CI. with good exhaust.
Old Dec 3, 2003 | 11:26 AM
y2khawk's Avatar
Compared to what?
A P-trim .81 in a T04 turbine housing is a little small for a single IMO. A tang housing would be better if you have to go /w the 81.
I'd go with a .96 personally.
my twins are .69 P-trim on-center. They spool by 3500 or so
Old Dec 3, 2003 | 02:27 PM
Originally Posted by y2khawk
Compared to what?
Thanks Harlan, and the rest of you guys.
Can one of you explain the .81 and .96 numbers? What part or function are they describing on the turbo?
Old Dec 3, 2003 | 02:38 PM
y2khawk's Avatar
A/R = area of the discharge scroll on the housing versus the radius from the shaft of the turbo.
think of it like putting your finger over the end of a garden hose. a smaller hole, and the water comes out faster but you can't get as much out in a given time. That's like a smaller A/R
bigger hole and the flow is slower, but you can get more flow over time.
faster flow will reduce spool time, but limit top end flow capability.
Old Dec 3, 2003 | 03:17 PM
Ah ok! Damn, I liked that laymen's explanation. Thant told me more than the 3 pages I just read on turbos lol.
Couldn't find what a "tang...somthingoranother housing" was though How does that help the smaller A/R?
Old Dec 3, 2003 | 03:35 PM
RyanJ's Avatar
SSU Moderator
buy last months hot rod. nice info on all that stuff.
Old Dec 3, 2003 | 03:57 PM
y2khawk's Avatar
Tang is for tangential versus on-center for the housing style.
Refers to the location of the inlet to the turbine housing, as in the inlet is tangential to the scroll. Tang housings are generally a little more efficient, but on-centers are nice for packaging. Tang housings usually have a V-band style discharge which is nice of the downpipe fitting, while on centers use the standard 4 bolt T04 style flange.
On-centers are nice cause you can upgrade sizes and things stay in the same place.
you can see the difference here...
http://64.225.76.178/catalog/thousing.html
Old Dec 3, 2003 | 04:49 PM
MYTURBOT/A's Avatar
[QUOTE=y2khawk]Compared to what?
Damn it i Always get that fliped around thanks for bringing that to my attention Y2KHAWK.
Old Dec 3, 2003 | 10:28 PM
As usual, a perfect answer to my uninformed question. Thanks Harlan.
BTW,I was looking at all of the graphs for the different turbos on the website that MyTurboTA recommended.
When comparing turbos is the max rpm that it spins and flow per min the major things to look at when deciding what is best for your engine?
Old Dec 4, 2003 | 07:09 AM
RyanJ's Avatar
SSU Moderator
take engine airflow in lb/min (cfm x .07) at redline (x-axis on comp. map) and look at boost as pressure ratio (14.7 + lbs of boost) / 14.7 (the y-axis). more efficiency is better.
