lightweight flywheel for the street? (with turbo)
Old Oct 6, 2009 | 02:58 PM
KILLER-LS1's Avatar
Default lightweight flywheel for the street? (with turbo)
hey guys, im building a 402 with a front mount turbo, and am wondering if you guys run a steel flywheel or aluminum on the street. What are the pros and cons of it being used with a turbo? im thinking it will spool faster, but not sure if there is any down-side on the street.
thanks!
Old Oct 6, 2009 | 04:00 PM
HUNTER02SS's Avatar
Use a steel flywheel. The extra rotating mass will help spool the turbo quicker than a aluminum. If this was a N/A setup then you would use a Aluminum flywheel.
Old Oct 6, 2009 | 04:08 PM
KILLER-LS1's Avatar
is that because there is more load with the heavier flywheel??
Old Oct 6, 2009 | 04:19 PM
HUNTER02SS's Avatar
That is correct!
Old Oct 6, 2009 | 04:32 PM
hissin'98's Avatar
I'm using a zoom twin disc package with the alum flywheel and i like it. It requires a little more rpm for initial movement but i don't notice it after rolling.
Old Oct 7, 2009 | 02:16 PM
KILLER-LS1's Avatar
anyone else?? id really like some info so I can order my clutch and flywheel!
Old Oct 7, 2009 | 02:19 PM
ninetres's Avatar
ALUM. SPOOLS SLOWER. Is that what you are after? If so, order away!
/thread
Old Oct 7, 2009 | 03:10 PM
TurboBandit's Avatar
steel flywheel for boost. you want to keep the engine spinning through shifts. Momentum baby!
Old Oct 7, 2009 | 03:22 PM
ls2formula's Avatar
I've also been told that a heavy flywheel and drive shaft help with traction.
Old Oct 7, 2009 | 03:31 PM
Super Slow SS's Avatar
Im in for staying with the steel unit on a turbo car, more load on the engine = faster spool.
Old Oct 7, 2009 | 05:03 PM
vipvegas's Avatar
All STEEL here..
Old Oct 7, 2009 | 05:10 PM
KILLER-LS1's Avatar
Ok, thanks guys, just wanted to see multiple opinions...
