Fireball Outlaw Drag Radial Rebuild Thread
#1623
im looking at your vid again, and I see that you are able to leave on the green. I cant do that as if I do I wont have the rpm or boost, and my 60 will be a 1.7
one thing I notice you do is build boost before the second bulb. i havent tried that yet - how much staging time will you say that cuts when you actually get to the second bulb vs if you used no footbrake
#1624
Restricted User
#1626
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
#1628
how are you doing that, if you dont mind? also related, how big a trans cooler are you using? thanks
timing is at 40 degrees in the brake.
i do have a couple of pinhole leaks in my coldside that i need to fix.
also, have you found turbo blankets to help with spool?
#1629
footbrake (dual calipers), until it hits first revlimiter, bump in to the beams and apply transbrake.
#1630
Restricted User
Stock brakes. You just have to have 2 2-steps. One is activated by the footbrake and the other is on the tbrake. You your first one starts popping at whatever the max that your footbrake can hold and starts building boost as you bump into the 2nd light. Then the launch 2 step kicks in when you push the tbrake button and release the foot brake.
#1632
where do you have your footbrake rev limit set at rpm wise?
#1637
Coal Mining Director
Mine is kiddie stuff compared the the VA Speed, Fireball, etc stuff, so it's not a very good comparison...
3850 race weight with AC. 325's or TT5's. 3.25, 428LSX, TwinTC76's,Rossler and Chance, BS3.
Pass this summer at 4500ft DA. 95F air temp:
http://www.streetfire.net/video/hawk...ol_2262336.htm
