Fireball Outlaw Drag Radial Rebuild Thread
Old 10-21-2011, 10:55 AM
  #1841
Fbodyjunkie06's Avatar
That's an interesting move, it'd probably be a little easier on parts, and I bet you could spool that LF88 a little better than the 106. Don't the PTE LF88 and the 106 you have share the same turbine? 111mm right?
Fbodyjunkie06 is offline
Old 10-21-2011, 11:00 AM
  #1842
Fireball's Avatar
yeah...it'll basically be a drop in replacement. turbine side is identical.
optimizing the 427 motor for the 88 wheel will be interesting...don't think we can rev very high so efficiency will be key.
Fireball is offline
Old 10-21-2011, 11:05 AM
  #1843
What do you shift at now?
Old 10-21-2011, 11:06 AM
  #1844
Fireball's Avatar
about 8500
Fireball is offline
Old 10-21-2011, 11:08 AM
  #1845
I'd think with a little different cam profile you'd be able to make all that work no?
Old 10-21-2011, 11:10 AM
  #1846
Fireball's Avatar
more than a cam...gonna need to get after it early. gonna take some compression too we think
Fireball is offline
Old 10-21-2011, 11:12 AM
  #1847
I think with the 427, smaller compressor with the 88, you will be able to get after it plenty in the first 330'.
I'm glad to see your keeping her in the stable. Good luck and can't wait to see what you, shawn and phil cook up next!:thumbsup:
Old 10-21-2011, 11:59 AM
  #1848
lt1camaroman93's Avatar
Good luck to you! I'm going down the same path, but going with the LF85 as I can't see the LF88 being worth the extra 200lbs. I'm trying to figure out some subtle changes for my motor to help get this done. Oh yea, I'm trying it with a 4 bolt motor! lol. This should be interesting.
lt1camaroman93 is offline
Old 10-21-2011, 12:48 PM
  #1849
Fireball's Avatar
considering I'm already 3340, I'll just have to add some weight up front...it wanted to wheelie anyhow when we got after it.
Fireball is offline
Old 10-21-2011, 01:03 PM
  #1850
Fireball's Avatar
picture of car from lsx shootout
Attached Thumbnails Fireball Outlaw Drag Radial Rebuild Thread-nmca_picture.jpg
Fireball is offline
Old 10-21-2011, 01:14 PM
  #1851
ATVracr's Avatar
Dont over think it Just bolt it on and see where your at.
JMO.
ATVracr is offline
Old 10-21-2011, 01:16 PM
  #1852
Fireball's Avatar
JMO.
hard to change things like compression if you don't think about it first
Fireball is offline
  #1853
Fireball's Avatar
video of 7.72 run
http://www.youtube.com/watch?v=VhMsNuTzdEI
Fireball is offline
Old 10-21-2011, 01:33 PM
  #1854
ATVracr's Avatar
I'm saying bolt it on to what you have.
Unless you have it apart already.
ATVracr is offline
Old 10-21-2011, 01:35 PM
  #1855
ATVracr's Avatar
Were you waiting for a personal invitation?
Green means go. LOL !
I know its qualifing and it doesnt matter .... Just messin with ya.
ATVracr is offline
Old 10-21-2011, 01:41 PM
  #1856
Fireball's Avatar
I was just daydreaming haha.
Fireball is offline
  #1857
Fireball's Avatar
um...thats really not possible
Fireball is offline
Old 10-21-2011, 03:05 PM
  #1858
koolrayz's Avatar
Im in the same boat as far as the 427 in X275. Im thinking low (under 7500rpm) and high compression is were I am going with the new car.
koolrayz is offline
Old 10-21-2011, 03:08 PM
  #1859
Ponyhntr's Avatar
When you guys say high compression, how high is that? 11:1? 12:1? I know lots of other FI racers are going that route.
Ponyhntr is offline
Old 10-21-2011, 03:14 PM
  #1860
chris@hps's Avatar
X275 is 4.70's-4.80's on a 88mm.
Chris
chris@hps is offline
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
