Oring'ed Heads... who's done it?
The double oring should work fine in a LSX block. The only blocks I have had problems with is the stock iron or stock LS2. I have not had enough experiance with the Warhawk, but my guess would be it should work.
Kurt
Kurt
Kurt,
would you recommend doing the o-ring on the block if the block was aftermarket as well?
i know that you're going to say that both a LSM 7075-T6 billet and Dart 6061-T6 billet machined blocks will be just fine,
but what about something case like a warhawk? or LSX?
in other words, instead of the o-ring in either the head or the block, it would be in both? but with an aftermarket block?
thanks for the time
_
thanks for the time
_
You think if you run the double oring setup and run the innermost oring in the head and then the outer ring in the block is a good setup?
Would this resolve the issues you find in the surface cracking?
The steelrings for the block were supplied by Trollspeed in Sweden when i put my engine together 2.5 years ago.
Obviously many has done this a long time before me.
Sorry for the "euro ideas" , "scandinavian talk" I just thought i would share.
Regards Marko
The double oring would compound the issue as the force on the sleeve column goes up. If you do that set up on a stock iron or aluminum block the results will be a cracked block on the LS design.
Kurt
Kurt
