Cheap Heads for D1SC
Old Oct 19, 2009 | 09:20 PM
AFASTYZFR1's Avatar
Default Cheap Heads for D1SC
I am running stock 241 heads right now Would it be worth it to buy a set of 317's, mill them a bit so my compression stays the same (9.5), have them ported and polished, and a 5-angle valve job....? Or should I just wait for more funds to get some AFR's ect....?
Old Oct 19, 2009 | 09:55 PM
conan's Avatar
I have 317's and next time I buy a set of heads I'm going with AFR's. I havent had any problems with the 317's (great so far) it would just be nice to have the thicker decks and a better flowing head. How much $$$ are you looking at for the heads, machine work, stainless valves, springs/seats?
Old Oct 19, 2009 | 11:23 PM
cablebandit's Avatar
afrs...etps..tfs...
Old Oct 20, 2009 | 01:07 AM
Zeke34's Avatar
+1, I've had 317 heads with a valve job for over 6k miles and they've worked just fine for me. If I had the money, I would have definitely been nice to have a stronger and better quality set of heads.
Old Oct 20, 2009 | 04:48 AM
EPP's Avatar
EPP
I'd save your money and wait and get a set of AFR's, with your forged engine this would give you the option to really crank up the boost. Bob
Old Oct 20, 2009 | 10:16 AM
AFASTYZFR1's Avatar
Little D1 is basically maxed out already But I will save up for some nice heads...hopefully I will give you a call next summer. And I want to upgrade to a F1 haha
Oh, and I really appreciate you taking care of the motor Bob! It hasn't missed a beat and it has over 7k HARD miles. EPP's motors hold up great!
Old Oct 20, 2009 | 11:02 AM
jt76's Avatar
not to hijack your thread, but what kind of power are you making with your D1sc being "maxed out?"
Old Oct 20, 2009 | 11:30 AM
AFASTYZFR1's Avatar
made 575 on 10psi but never got any numbers on 15psi
Old Oct 20, 2009 | 11:49 AM
Rickys S/C Z28's Avatar
just wait and get some good heads i wish i would have, and why is the D1 maxed out? i trust on here makes 17-18 ps1 and runs 9's with his car
Old Oct 20, 2009 | 11:59 AM
02SSLE's Avatar
I agree wait and buy good heads.
Old Oct 20, 2009 | 12:37 PM
AFASTYZFR1's Avatar
I am running 7.25" crank and 3.4" Reichard blower pulley spinning to 6800 (also have sdce), so that is about 59k rpms.....pretty close to max and only see 15psi
I am looking for a 7.65" crank pulley to spin it a bit faster....11.0 @130 slipping clutch from 4k (on nittos). So the mph is there but I don't have it set up for the strip so I am having trouble getting off the line. Car also probably weighs 4000lbs
