Poor man's method to better belt wrap on an fbody
Here some more pics
In other words, ***I'm not responsible if you F things up using the dimensions that worked for me!*** LOL!!!
https://ls1tech.com/forums/12402970-post29.html
As you can see, it works as designed if you do it as designed.
If you get the vortech pulley, I'd recommend changing the bearings in it from the start. If you rev to 6500rpm, with a 7.65 crank pulley, you will be spinning that 2.5" idler 19,890rpm. So get a bearing (or bearings-not sure if it uses 1 or 2) that can handle the rpm.
Not that procharger is a TON better because I see procharger bearings fail too. I suspect it is because they incorrectly match their bearings as well. The only bearings I have taken out of a procharger idler were out of a used one, so I dont know if the bearings in there had already been replaced or not, but the bearings I took out were only rated at 14,000 rpm. Since the procharger bearings are 6003's, when the procharger bearings fail, I'd replace them with these.
One thing you gotta watch out for on bearings is the brand. Sure, you can get cheap bearings that have a good rpm spec for a couple dollars, but cheaply made bearings are no better than a quality bearing thats not rated correctly for the job. Infact, the cheapo bearings would probably be worse.
Just weighing my options, Damn it sucks to be cheap
Again Chevy chads specs are good, I just feel the factory idler is not wide enough. If you have a procharger then this mod is a must unless you have aster's or sdce tensioner. I wanted to do asters but the price didnt sit well with me
This angling of the bracket is also causing the belt to ride harder on the sharper edge of that pulley than the side closest the bracket with the rolled edge.
You counterbored the bracket, so you need to make up for that on the bracket side of the standoff, not the motor side. Notice that the thickness of the gold washer you have on the motor side is equal to the overhang of the belt on the pulley? By counterboring the bracket, you effectively shifted everything over towards the bracket. If you removed the thick gold washer on the motor side, and put washers back in the bored out part of the bracket, it would all shift back into place.
Also in that picture you showed it appears that the pulley is not sitting truly perpendicular, but instead is riding at an angle. It also appears the bracket is not truely square when compared to the stand off angle in the image. It might just be a trick of the angle of the photo, but it does not look right.
ID: 10.15mm (this is smaller than the 17mm this mod was made for)
OD: 76mm (this is 2.99" same as the stock fbody idler)
Width: 30mm (this is approximately the same width as the stock fbody idler)
You swear the stock fbody idler wont work for you, then you turn around and spec out a pulley thats almost identical in OD and width, but has a worse ID. I dont get it man..
