Poor man's method to better belt wrap on an fbody
Old Dec 29, 2010 | 10:16 AM
  #161
bpope's Avatar
Thanks for the help man! I am just going to run the 3" idler as you have been running it and I know it should work. Now...just need to find a 3" idler.
Thanks again!
Old Dec 29, 2010 | 12:33 PM
  #162
ChevyChad's Avatar
8 sec potential, 12 sec slip
No problem man. The stock fbody idler puley is 3" (its what Im using). Its like $24 at Oreilly. Part Number: XXXXX
***edit, correct part number for the wide idler to be used for the 8 rib is 38041 and its $41 from Oreilly***
Apparently, there are 2 different ones as found out by pdasterly on pages 12-13 of this thread. My apologies for the confusion.
***edit #2*** Alternatively, there is a similar 3" pulley from autozone that is $17. Part number for it is 231107.
Old Dec 29, 2010 | 01:40 PM
  #163
bpope's Avatar
Cool
Originally Posted by ChevyChad
No problem man. The stock fbody idler puley is 3" (its what Im using). Its like $24 at Oreilly. Part Number: 36220
You the man.
Old Dec 29, 2010 | 10:15 PM
  #164
pdasterly's Avatar
When you used the stock idler was It the original design pulley or the new design. I know gm revised the alternator bracket because when I ordered a new bracket to modify for my turbo kit the old idler wouldnt fit so I had to order the new style idler, which is the only one they carry now.
Old Dec 30, 2010 | 05:23 AM
  #165
ChevyChad's Avatar
I really have no clue. Whats the difference? Either way though, it should work, worst case you'd just have to space it out or in with a washer or two.
Old Dec 30, 2010 | 03:22 PM
  #166
pdasterly's Avatar
last question before I have this done to my bracket. What is keeping the second idler pulley from rubbing the j bracket. Even with a machined standoff would some washers be needed to keep pulley from rubbing bracket?
And last some please take my money and modify my stand My local machinst is on vaction
Old Dec 30, 2010 | 03:49 PM
  #167
ChevyChad's Avatar
Of course you need washers to space it to where you need it to be and to keep it from contacting the bracket.. I take it you have not read this whole thread LOL
Second, I cant take your money right now, I'm on vacation myself. In Brazil.
Old Dec 30, 2010 | 04:11 PM
  #168
pdasterly's Avatar
Ive read it too many times. too bad we cant just buy the bottom part on asters bracket. also in his diagram they show the standoff as two seperate pieces
Old Dec 30, 2010 | 04:34 PM
  #169
ChevyChad's Avatar
I thought someone asked the question before about how to keep it from contacting the bracket..
*edit: found it. See post #58. Also, post #101 shows them in the diagram
On Aster's setup, that short piece is just a spacer.
Old Dec 30, 2010 | 04:51 PM
  #170
Aster's Avatar
Actually on my bracket the short piece and the hex standoff have shoulders that support the two bearings used in my smaller pulley, one through each bearing. The two parts also sandwich on either side locking the pulley in place so it can not move.
Old Dec 30, 2010 | 05:45 PM
  #171
ChevyChad's Avatar
Thats what I call a spacer .. But I just didnt want to type out all the details. Your bracket is awesome, and it was what inspired me to put the extra idler on my stock one. Someday I'll actually put some effort into fitting up a spring loaded tensioner onto the stock bracket as well.
Old Dec 30, 2010 | 06:08 PM
  #172
Brigger18's Avatar
How tight are you guys tightening your belts now? I was hoping this would lighten up a lil on the bear load.
Old Dec 30, 2010 | 06:15 PM
  #173
01boydws6's Avatar
I tighten mine down until I can barley fit my finger between the two pullies, tighten the jam nut and give a 1/4 turn
Old Dec 30, 2010 | 06:27 PM
  #174
Brigger18's Avatar
Is it still like a guitar string.
Old Dec 30, 2010 | 06:34 PM
  #175
ChevyChad's Avatar
I get mine pretty tight. Not as tight as I did before without the extra idler, but I still get it hella tight.
Old Jan 1, 2011 | 05:27 PM
  #176
Brigger18's Avatar
Anyone use the 12 rib pulley's yet?
Old Jan 1, 2011 | 05:30 PM
  #177
ChevyChad's Avatar
That would require extensive modification for clearancing the radiator area. My inlet hat is already contacting my radiator, so I cant imagine trying to gain any more room and keeping the AC. If you ditched the AC and did a vertical radiator you may be able to, but I'm not sure. I am not gonna sacrifice my AC on my street car.
Old Jan 2, 2011 | 01:31 PM
  #178
Taubr Unit's Avatar
didnt even know they had a 12-rib kit! Whats this you speak of??
Old Jan 4, 2011 | 05:10 PM
  #179
Brigger18's Avatar
Brute speed has the 12 rib. I was looking at the crank pulley and it looks like it spaces the ribs about an 1 1/2 away from the balancer before the ribs begin. http://shop.brutespeed.com/ATI-DCxxx...?categoryId=-1 Looks like its more designed for a SC that sits on the other side with the other accessories. Still looks like it could be made to work tho. I think I'm gonna check into a cog setup first.
Old Jan 13, 2011 | 01:44 AM
  #180
pdasterly's Avatar
anyone have luck having this made
this is the only place online I can find and again the machinist is on vaction, damn it george
