Injector size
Old Dec 7, 2003 | 04:35 PM
Blown98's Avatar
Default Injector size
Right now im running 9.5 psi and have the 34 or 36 lb injectors that came with the kit, i dont remember which ones they are but my Question is should i go with bigger ones. i noticed that some of you guys are running around 40 lb. Any suggestions will help, thanks
Old Dec 7, 2003 | 05:04 PM
TwnTrboCE's Avatar
Was your car tuned with those injectors? How was the A/F? What RWHP are you looking for? This will decide what size injectors you need.
Old Dec 8, 2003 | 01:48 AM
Blown98's Avatar
i know quite a bit about motors and such but i dont know much about the A/F ratios so i had it tuned and that was with those injectors and it put out 485RWHP and 495TQ, can i get more power just by getting bigger injectors? i would like to end up with 550-600 RWHP in the end.
Old Dec 8, 2003 | 02:25 AM
BIGBOS's Avatar
I would at the least use the 42.5's........
Old Dec 9, 2003 | 02:30 AM
Blown98's Avatar
if i get bigger injectors do i have to get it re-tuned? how much more power can i expect?
Old Dec 9, 2003 | 06:56 AM
y2khawk's Avatar
If you change injectors, you will have to re-tune.
Unless you were out of injector before, simply changing to a larger injector will gain you no addition power. But, with larger injectors you can up to boost for additional power.
Old Dec 9, 2003 | 03:54 PM
Blown98's Avatar
i have the superchips hand held tuner, will i be able to tune it for the injectors with that?
Old Dec 9, 2003 | 06:23 PM
30thta436's Avatar
if you have the Vortech kit, the 38lb injectors should get you close to 600 RWHP. you will have to tune for bigger injectors. No the superchips tuner will not work, unless you send it back and have them put in a custom tune.
Old Dec 9, 2003 | 09:43 PM
Blown98's Avatar
ok thanks
