2in arh
Old Nov 2, 2009 | 05:27 PM
02 z/28's Avatar
Default 2in arh
do you guys think 2in headers would be overkill on my car?car is a 365 f1a and 16 psi thur an automagic.thanks
Old Nov 2, 2009 | 05:58 PM
trans2000am's Avatar
yup da end close thread
Old Nov 2, 2009 | 06:06 PM
93formto98T/A's Avatar
Overkill=no, Unnecessary=yes With FI you want to get rid of exhaust gases without building backpressure. I doubt you'd see much hp difference 1.75" to 2" given your specs.
Old Nov 2, 2009 | 06:17 PM
02 z/28's Avatar
right know the car put down 730rwhp on epp mustang dyno with 1 3/4 headers.they could only take it to 5900rpm due to it running out of fuel,now the car has a full fuel system alkycontrol meth kit,and just trying to find the right headers before I take it back.
Old Nov 2, 2009 | 06:44 PM
OUTLAWZ RACING's Avatar
1 7/8 Will show a minor gain but overall it will run alot harder due to less back pressure. I say ur doing good with the 1 3/4, But frost I think on this board runs 1 7/8 and is around 800+
Old Nov 2, 2009 | 07:20 PM
we ran out of fuel on his car so couldnt take the car any further, this is also an auto car
Old Nov 2, 2009 | 10:37 PM
Jimmy P's Avatar
I say go for it...I have ARH 2" headers on my car..402, around 10:1 compression, 18.5psi, TH400 + 9" = 812rwhp on a Mustang dyno
Old Nov 2, 2009 | 11:03 PM
Inspector12's Avatar
TT-TECH Veteran
Ran 17/8 on the 408 and made all I wanted lol! And now I am running 2" Kooks on the 346 with the F1R. Is is needed no. Does it make a difference you have to be the judge. If you are buying headers anyway. Well I probably would buy the 2" as it won't hurt you.
Old Nov 3, 2009 | 06:11 AM
Its still a strong running car Im sure with the fuel is work out it will be even better. Like jeff said 2 inch wont hurt nor will the 1 7/8. Im not sure on the gains but it will be over 800+
Old Nov 3, 2009 | 04:05 PM
02 z/28's Avatar
thanks for the help fellas.
Old Nov 3, 2009 | 04:57 PM
let me know when you need ur mechanic/fab guy to come install them ill bring my grinder and saw
