Highest boost level to run with stock bottom end ls1?
Old Nov 16, 2009 | 11:47 AM
CaMaRo67RS355's Avatar
Question Highest boost level to run with stock bottom end ls1?
thinking of purchasing a aps twin kit and was wondering what is the highest amount of boost i should put on the stock bottom end.
any other info you wanna give me with running a stock bottom end let me know im all ears
thanks
Old Nov 16, 2009 | 11:58 AM
gt35built's Avatar
Theres no actual highest boost level that it will withstand as it varies on the motor. I would stay under 10 pounds although some have gone higher. Some guys run 5-8 psi on a safe tune and seem to last. others blow it real quick.
Old Nov 16, 2009 | 11:59 AM
Floader's Avatar
how long do you want it to last? I have run 8-9psi for the last three years. makes 550+rwhp. do a search
Old Nov 16, 2009 | 12:25 PM
JAX04's Avatar
https://ls1tech.com/forums/forced-in...lity-list.html
Old Nov 16, 2009 | 12:59 PM
crf538's Avatar
ive had mine on 14 with half race gas, 12 on pump and methanol, both are prolly pushin it a little, about 8-9 with meth and a good tune seem to do fine
Old Nov 16, 2009 | 03:40 PM
LS1x2's Avatar
Formerly 4mulaJoe
18psi here on 93+meth
Old Nov 16, 2009 | 08:58 PM
robert miller's Avatar
Man if this is on a stock bottom end you have one hell of a tuner. And how long have this set up been on the car. Also how much do you get into boost.
Old Nov 16, 2009 | 09:04 PM
98Z28CobraKiller's Avatar
Restricted User
I stretched the stock rod bolts at about 17 psi. All the good tuning in the world wouldn't have helped that. It ran 6.24 @ 112 in the 1/8th on that pass.
Old Nov 16, 2009 | 09:06 PM
BLWN1's Avatar
Fasttrack out of Louisville Ky I believe went 5.96 1/8 th with a cam swap. Im sure he ' ll reply eventuall..
Old Nov 16, 2009 | 10:32 PM
MY99TAWS6's Avatar
Well how deep are your pockets ,meaning if you blow the stock engine can you afford to buy new one or the downtime on the car?
The aps kit was set up for basically stock motor and comes at 7.5psi. My advice is leave it there. If you drop compression with some 317 heads then maybe a few more pounds. But stock ringlands are fragile ,seen many blow to hell ,not my car as I didn't run my aps kit on stock engine.But mistakes on sts cars, ati cars.
So don't be greedy. Run stock springs,7.5 psi. Run intank pump like racetronix ,60 pound injectors ,stock lines are fine at stock reg and rails. Be conservative on tune,timing especially. You can run alc injection for extra safety, 50/50 stuff or 100% meth your choice.Make sure you monitor things carefully ,handy to have incar monitoring of stuff ,my interceptor gauges work great as don't want to have laptop with me 24/7.
Put in better valve springs into the stock motor right away. And thats about it.
These guys telling you they run 18psi on stock engines are same guys that would play Russian Roulette. Local guy has sts on stock engine. He has ran 5psi for few years. No problems. Its not so much the psi though as the airflow. But 7.5psi on the aps kits should be ok on stock motor. Be more worried about the turbos dying then the engine at 7.5 psi if things are tuned right.
Old Nov 17, 2009 | 01:27 AM
bondosgto's Avatar
aps quit making kits for gm v-8's. good luck finding a kit
Old Nov 17, 2009 | 06:17 AM
LS1x2's Avatar
Formerly 4mulaJoe
I tune it myself. It is a stock bottom end. It's only been about 5k miles. It sees full boost pretty much every time I take it out.
Old Nov 17, 2009 | 05:23 PM
black98ws6ta's Avatar
U got a dyno graph? Timeslip? I thought I was running alot of boost, lol. What kind of timing?
Old Nov 17, 2009 | 05:44 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
10 pounds or less on a conservataive tune will be preety solid. Anyhting higher and you are for sure on borrowed time. One of my buddies is running 12 pounds on his SS and running 10s. So far so good. But he knows its just a matter of time before Boom!
Old Nov 17, 2009 | 11:54 PM
do you know what cam he put in?
Old Nov 17, 2009 | 11:57 PM
so basically its kinda of up to me but most suggestions tend to lean toward below 10 lbs... i think i will take the advice of MY99TAWS6 and just leave stock springs in right now and then down the road change it. id never run 18psi on a stock bottom end thats crazy.
Old Nov 18, 2009 | 01:45 AM
A big one for a stock short/longblock. 240+ duration, .600+ lift.
Old Nov 18, 2009 | 06:29 AM
LS1x2's Avatar
Formerly 4mulaJoe
The car has stock heads, 218/228 cam, 1 7/8 headers, hi-flo cats, and a stock catback.
Old Nov 18, 2009 | 07:25 AM
dreamls1's Avatar
12psi, 93. 700whp. and going strong.
