How do opened wastegates sound off boost?
I'm just trying to get my cake and eat it here. I don't want to pay for a pair of twins but I know I'll miss the sound of side pipes when I'm cruising about. So I'm thinking of doing a single and having twin wastegates going into open pipes heading down either side of the car. Then I'd use co2 to run the gates so I could open them at cruise speed.
Now the question becomes what would I hear? If I muffle the main turbo pipe these should completely overpower it right? I'd think so but as it's such a comparatively small set of exits I wonder if they'll have a lot of volume before the whoosh of the turbo starts coming through them.
I just know I'll miss that left/right rumble from the sidepipes if all cylinders are dumping into one pipe. Even having the single pipe split to either side I don't think would give the same sound.
to compound this, if both banks where exiting from the crossover pipe THROUGH the wastegate, its gonna sound the same as a cutout... just worse.. unless your wastegate opening is 3" DIA. in that case, you have a diesel from a dump truck in your camaro.
MY POINT: its gonna sound like a silly HORRIBLE exhaust leak if you run the w/g open on out of boost.
A wastegate was invented to regulate pressure in the exhaust system entering a turbo. Not to regulate your cool factor.
If you want something that sounds "cool" at idle with some whistling sounds and some pulsing, perhaps you should get a blower and get it surging real good during idle. Improper fueling and/or timing will get you there.
Now as for why I'd do it just for a sound, why do people ride harleys when streetbikes are faster?
Obviously, there's more to it than just the sound, but it plays a part.
Another good example are Ferraris, which often have a lot of R&D put in to getting that certain sound.
This car has always had a certain sound ,though clearly not a ferrari sound, and it's a big part of my enjoyment with it. It's one of the first things I miss when I put it away for the winter. Though my winter car is fun, four cylinders just never has the same... presence.
Wastegates are only devices, they do or don't do whatever we want them to. I can see no reason why they wouldn't perform this task, whether specifically designed for it or not.
As for "cool" factor, I like to keep things low key, standing out is not my style.
In fact, I think the best part of this when it's all finished is that I won't have to listen to it driving around downtown. But once I've got a weekend to just eat up highway, I'd love to keep the feel it has now. With the windows down and the thump of the engine rolling the miles by, it's an awesome experience.
This sounds like a job for an electric cut out, itll be cheaper and easier to do and will gave you the same shitty sound youre after. It will sound like an exhaust leak.
I'm still not sure why it'll come out like an exhaust leak. Simply because there is enough size potential here to flow as much as stock, which would be far less an impediment than flowing through the turbo and then through mufflers.
