422 LSX Solid Roller, TFS 245's, Billet Wilson & Twin TC78's from KYTP
Old Nov 18, 2009 | 07:22 PM
CBIII's Avatar
.this thing should be SICK!
Old Nov 18, 2009 | 07:48 PM
LS1-NAVY's Avatar
wow great progress keep it up and make sure to get vids
Old Nov 18, 2009 | 08:03 PM
wilson34's Avatar
Ya welding with some welding sleeves and a cut up sleeveless shirt was never my best idea, especially when it was summer and everyone saw my burns.
Old Nov 18, 2009 | 08:52 PM
raymond mckinney's Avatar
Can't wait to see this thing run at a dead hookers event! You guys always do nice work.
Old Nov 18, 2009 | 08:58 PM
Tiago's Avatar
nice build, love the headers/turbo positioning
Old Nov 18, 2009 | 10:25 PM
LASTLS1's Avatar
6 Second Club Moderator
Nice build, keep up the quick work. You'll have it done in no time!
Old Nov 18, 2009 | 11:33 PM
STEALTH TURBO C5's Avatar
That's a bad *** ride ! Good luck with it .
Old Nov 19, 2009 | 05:52 AM
venom ws7's Avatar
Looks like a very nasty build for aure good luck with the rest of it.
When the car was 408ci with 400shot it was sick on the street I can't imagine this..
Keep us posted,
Old Nov 19, 2009 | 08:43 AM
DrTurbo's Avatar
LS1TECH Sponsor
You will love the TC78's. Let us know when you get the sucker on the track!
Old Nov 19, 2009 | 08:51 AM
Inspector12's Avatar
TT-TECH Veteran
Whats the problem with the power steering. Just curious as it looks like there is plenty of room. The build looks great. Always loved that intake, it was just pricey for sure.
Old Nov 19, 2009 | 09:10 AM
98Z28CobraKiller's Avatar
Restricted User
Water tank arrived yesterday as promised.
Looks sexy. Thanks Josh.
Old Nov 19, 2009 | 09:23 AM
  #32
LT1_bob's Avatar
That car sould fly.
Old Nov 19, 2009 | 09:39 AM
  #33
Restricted User
Would be nice if we could make some money at it. I just hate turning wrenches.
You are one of the guys that I did some research on while trying to decide in which direction to go. How's yours coming along? Steve mentioned that he saw you were selling your block and maybe trying to switch over to 6 bolt.
Keep us posted,
The good old days. Before the ricers fucked up our street scene.
Here's me and Steve doing battle on the streets on motor. Video is from his car. I dinged the limiter on the first one.
http://www.youtube.com/watch?v=FzCKEd54Gwc
There will be video.
Pulley rubs the header. He can get a smaller pulley, i think but the reservoir ends up right up against it. Would be nice if someone made an electric power stearing setup for the Fbody with a remote reservoir and pump.
Old Nov 19, 2009 | 10:51 AM
  #34
RS_SS69's Avatar
Vortech makes a relocation for the reservoir and a different pulley to mount to the head. Its a billet pulley and they might be able to get one in a smaller diameter. Tell him to call vortech and check it out.
Old Nov 19, 2009 | 06:44 PM
  #35
Restricted User
He called Vortech today and got put on perma-hold.
We did make some progress in a couple of other areas after a few hours of head scratching. He had cut off the horns for the bumper support in an effort to shed some weight. Ofcourse, now we need them in order to attach the front IC/Bumper support. Dave made up some brackets for us to use this evening and I dropped off the radiator again so that he could move the top AN fitting down a little in order to clear the exhaust housing on the driver's side turbo. Also dropped off the charge pipe to have a bung welded in for the screw in IAT sensor.
We gave up on trying to jam the flex-a-lite puller in there. It was way too tight. Called up Flex-A-Lite and they are sending the opposite pitch blades for FREE (to make it a pusher). Now that's customer service!
We got most of the fuel plumbing done last night also.
Old Nov 19, 2009 | 07:42 PM
  #36
toretto's Avatar
still on regular gas, or going e?
Old Nov 19, 2009 | 08:37 PM
  #37
FLA 98TA's Avatar
Ahh yes his car was my blueprint while building my kit its pretty much identical.
Old Nov 19, 2009 | 08:40 PM
  #38
Restricted User
Initially will probably be running race gas (C16) to work out all the bugs. Then we will try the e85. Nearest E85 pump is about 30 miles away. We'll have to see how that works out.
Old Nov 19, 2009 | 09:55 PM
  #39
FLA 98TA's Avatar
only thing about e-85 is the insane amount of volume needed. I can't even run it in my secondary cell due to lack of volume. But if he went with enough fuel system e-85 is great.
Old Nov 19, 2009 | 10:46 PM
  #40
Restricted User
I believe that it has 2 MP-4301's rated at 1500hp each on the same tank. One will run all the time and the other one will kick on under load.
