Which Head Unit for 700+rwhp?
More research has provided that we may never find the theroretical limits of either block, but there is a problem with the resleeved blocks overheating and there have been 3 cases where the sleeving didn't take and they came out. It just sounds like to me that this is more of an expermental thing than something that should be used in production. If using IRON doesn't bother you, buy the 6.0 Liter IRON LS1/Vortec block. It can be had for about $900.00. I didn't want to have any possibilities of any problems so I bought the best that there was.
Bryan
Bryan
Trojan T/A - Here is a good thread on the new Darton wet sleeves:
https://ls1tech.com/forums/showthrea...ghlight=darton
The designers of the system give some great info...
If a person is buying stuff from scratch, and wanting 700rwhp, it's definitely worth buying the best head unit you can find that hits that power range without being massively overspun.
700rwhp on 91 octane might be:
400-427ci, 8:1
15 lb blower setup - F1, YS Trim, Novi 2000
FAST or DFI ECU system
83 lb injectors and complete fuel system
I'm not sure a 348ci + boost can hit 700rwhp on 91 octane, I will say that I think it would be hard.
I would expect a LOT more than 700rwhp with the combo you mentioned. My LT1 (inferior head wise to an LS1) made nearly 660rwhp on 12psi, with only 383ci. pump fuel.
Anyhow, If 700rwhp is your MAX goal, I would go with a t-trim. you will probably get close to that figure, but have MUCH better low end boost for street driving. a YS -trim at only 13-14psi will be much more lazy down low. YS trim is more suited for cars wanting to see 800+.
Spinnin a t-trim hard will get you good low end boost, and close to your power goals. Vortechs are known for their rock solid engineering, and can handle abuse.
Jordan, hitting 700rwhp on 91 octane sounds like a bit of a challenge to me. A 383ci + 15 psi might get there too sure I was more playing to the combos being thrown out earlier in this thread.
I think a 8:1 348ci motor + 15 lbs might get to 700rwhp.
825hp, =~ 717rwhp (assumin a manual, 13% loss)
Not to mention that is at max effciency, not what you can REALLY make out of it. people are making 650 with a S-trim!
I am expecting 700+ with 15psi/pump gas on my motor. I would think with an LS motor's heads, you would see at least another 80rwhp at the same boost.. maybe more. my motor "NA" probably only makes 380.
I was trying to guesstimate how much NA power I make, and I'd guess 350rwhp/380rwtq thru my T400.
As you stated, finding the right head unit is the best first step in looking for more power. The kits are good but only to a certain level.
BTW, what kind of fuel system are we looking at here. I understand 83lb injectors, but what about the fuel pump, and are billet fuel rails and a pressure regulator all part of the system as well?
83 lb Siemens injectors
SS Racing Billet fuel rails
Weldon FP regulator
-10 to the front, -8 crossover, -6 return
Weldon 2025 externa pump
FAST ECU system
Other way to tune without getting an aftermarket ECU would be to tune in speed density and get a Pro-M MAF. Or try to max out a set of 57lb injectors and try to tune with the the MAF working.
Weldon FP regulator
FAST ECU system
Pro-M MAF? What is this.
83 lb injectors are nice, however, in NC to pass inspection the inspectors have to be able to run an ODB II test, which means xnay on the aftermarket computer. I have to make this work with the Siemens 57#'s and the stock computer, I am running Aeromotive 1000 fuel pump, -10 feed -12 return, but none of that matters. It is all about the injector and the fuel pressure. You could have garen hose for fuel lines and it would not make any difference.
Basically when pushing the stock pcm you have some issues:
-run out of injector choices
-stock MAF gets pegged
-leaded gas kills 02 sensors
Pro-M sells custom MAFs: http://pro-flow.com/
Ask for Scott Beers and mention our site. He owes me a phone call.
Check this page out for an impedance converter.
http://www.ls1speed.com/catagory.cfm?catagory=fuel
Those 57#ers may do 900hp N/A but, not with boost. That would be pushing it I think.
THIS TRANSLATES TO: I CAN USE MY STOCK LS1 COMPUTER AND MAKE THAT HORSEPOWER. FUEL PROBLEM IS SOLVED
