98 Camaro 370CI T76 Build up
#61
camaro is pretty much done .. just need to build radiator hoses .. fuel lines and waiting for forcedinduction.com to send me my darn downpipe flange so i can finish up the downpipe and exhaust
#67
been sourcing flanges for the 1stgen ST80 i had. even forcedinductions.com didnt have it. finally put together a clamp and a flange setup thatll work. right now im gettin the supra up and running and then comes the camaro
#71
get the camaro going? are you running stock feed line off the tank? i was going to run twin intanks but im concerned about pick up problems, and i think your setup would be much better
#73
Are u wrapping that header on the supra? Looks big and hot when running and I see you didnt have it coated...or are you getting that done too?
Nice fab work BTW...makes me want to pracitice more now, one day, one day, I still have a tranny to fix
Both cars look nice, obviously likin the camaro more because, well, I have grown up in and around them my whole life.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#75
nope no coating no wrap.. i never really found coatings to be that helpful =T
#77
if you plan to depin the entire harness and run the wires through you can get the regular one. but if you just want to cover existing wire and not depin use this one
http://www.mcmaster.com/#sleeving/=64de3f
