backfiring =/
Old Dec 27, 2009 | 08:55 AM
gEtyOPaPiOn's Avatar
Default backfiring =/
ok so it didnt run for 3 yrs and now it backfires at wot under load
twin turbo
stock bottom
fast 90/90
e boost2
6 speed
Old Dec 27, 2009 | 09:01 AM
Pimpium57's Avatar
Change plugs and put good gas in it after sitting?
Old Dec 27, 2009 | 09:04 AM
i changed the plugs , wires and gas too
Old Dec 27, 2009 | 09:09 AM
Pimpium57's Avatar
Does it happen as soon as you get into any boost at all (at wide open) or only upper rpms?
Old Dec 27, 2009 | 09:44 AM
at upper rpms only
Old Dec 27, 2009 | 09:51 AM
Pimpium57's Avatar
Have any access to hptuners, EFIlive, or other software to scan it and post up a log?
Old Dec 27, 2009 | 09:55 AM
ill try to get one during the week ,thanks
Old Dec 27, 2009 | 09:57 AM
catz's Avatar
Check valve springs weak or broke ?
Old Dec 27, 2009 | 10:05 AM
Pimpium57's Avatar
It could be a fuel issue since it's only on the big end under WOT. In the meantime, I'd also check your fuel filter and make sure the plugs have the same gap you were running before to rule out it blowing out the spark.
Do you have a fuel pressure and wideband A/F gauge in the car? Does it still do it if you turn the boost down a bit?
Old Dec 27, 2009 | 10:14 AM
smokinHawk's Avatar
Make sue the plug wires are right messed up once
Old Dec 27, 2009 | 10:20 AM
Pimpium57's Avatar
x2
I'd use the exact same ones you were running before and make sure they're not resting on the hot parts.
A friend's 618rw Procharged car ran like **** with brand new Taylor wires on it. Got OEM Delco's from the dealer and it was fine.
Old Dec 27, 2009 | 10:46 AM
toddcod's Avatar
My first guess woulld be a gas issue.
Unless you are using a different tank. It will take a tank or two to get all the resedue of bad gas out.
I'd put some octane booster, or stp gum out in it. That way the injectors or carb jets get cleaned.
Are you carb or injected?
Old Dec 27, 2009 | 10:53 AM
MY99TAWS6's Avatar
I had machine gun noises on my tt a few times. It was burnt wires every time.Finally went to stock wires with stock ls1 heat shields and that works best,fancy granatelli wires cooked bad in my car. Never figured it was wires but it was.
Plug gap for sure can let spark blow out under boost. I run .028 with current autolite 103s.
You can turn up dwell if you have tuning program like hptuners or upgrade to truck coils.
Check fuel supply, filter,pump and hopefully you are not running out of injector.
It should be one of the above things and valve springs might be gone too.
Old Dec 28, 2009 | 07:44 PM
thanks for all the tips ill do that over the weekend and let you guys know whats up ....the sparkplug wires arent touching anything hot and they go arround the headers so ill look at that too ,ill look inside the valve covers too but the springs were new ,maybe a bad valve ?
Old Jan 12, 2010 | 11:30 PM
so I got it running again and found a couple of bad sparkplug wires =I hopefully this fixes the problem ,
Old Jan 13, 2010 | 01:12 AM
DeltaT's Avatar
You definitely need some sort of scan tool so you can monitor your data or you are flying blind. I wouldn't go WOT again without some data - creep up on WOT in small stages, confirming that your AFR and Knock Retard #'s are solid before you continue. Consider investing in some race gas for insurance against detonation while you troubleshoot. $50 in gas is nothing if it saves you a piston or valve, eh? I wanna see that thing running good again next time we meet
Jim
Old Jan 13, 2010 | 08:57 AM
MY99TAWS6's Avatar
Had the problem repeatedly. It was wires every time. Even cooked some very expensive granatelli wires. Finally went back to stock gmpp wires with the stock heat shields and so far seem to be fine. I didn't ceramic coat my exhaust manifolds and turbo exhaust housings but do plan on doing this sooner or later. I have heat shields on my exhaust manifolds from aps though. Course a lot depends on your particular setup.
As said other things that cause similar problems are spark plug gap.I run around .028 to .030 currently. Might go down to .025 at higher boost. Also iridium plugs last longer and you can run a colder heat range than the normal copper plugs people like to run.
I am currently running autolite think 103 but going to ngktr8ix this coming season.Plan on upping boost to around the 15 range for daily driving and 20 maybe occasional max.
At least plugs are pretty easy to change out on my setup.Seen some that are real nightmares.
Fuel is of course another thing that can affect things. Checking fuel pressure,making sure you have adequate fuel and the injectors are not at the end of their capability are good ideas, unrestricted fuel filter is a good thing.
But 99/100 when the car brakes up under wot and I called it a machine gun sound it is wires or plugs.
And it is a good idea to check valve springs every couple years and maybe even more often if you are running high lift and the springs are close. Turbos are hard on valve springs.
Old Jan 13, 2010 | 09:58 AM
well thanks for all the info ,I will replace the wires for sure but im kinda wondering where to get them ,last time i pieced some msd wires together ,is there any out there for custom lenght ? i run them arround the headers not straight down from the coil ,and the only diagnose equipment i have is a snap-on solus ,I dont have any hp tuners or efilive
Jim we will meet again soon !
