ATI Cog set up is here!
Old Feb 11, 2004 | 01:54 PM
  #261
BIGBOS's Avatar
The steel bracket or that bracket reinforcement that I posted pics of...........
My aluminum one didn't flex at all after that puppy.......the flexing will cause that belt to go easily.......
Old Feb 11, 2004 | 02:08 PM
  #262
HUGGER ORANGE SS's Avatar
Could you post them up again. I missed them.
Plus could you tell the cost involved and where you went to?
Old Feb 11, 2004 | 02:20 PM
  #263
frcefed98's Avatar
Neal get to work Check the appearance section for how much it will cost me for the dent.
Clint, Bos has a link on the previous page(first post or top post) for his support bracket. I talked to Z8's(good guy who made his bracket) and he said that he is working on a bracket, the hold up is the different length standoffs that the ATI kit use for the 6speed and auto, throw some washers in the mix and everything get even more complicated to make a support bracket. If he would make me one like bos has I could figure out the rest......I think
J
Old Feb 11, 2004 | 02:22 PM
  #264
BIGBOS's Avatar
I had Chris & Kurt Sikora do it for me, I will talk to him to see how much it will be to reproduce one......
http://community.webshots.com/album/50943416PqwcOb
They are in there under the 6.0L 372 pic section, the pics I took of it were when I was trying to sell the kit, I was focused on getting the pic of the blower instead of the support, but you can get the idea.........
Old Feb 11, 2004 | 02:26 PM
  #265
frcefed98's Avatar
Ha Bos beat me to it
Old Feb 11, 2004 | 02:32 PM
  #266
BIGBOS's Avatar
We need to start a new thread, but this thing is fillllllllllled with info..........27 pages now......
Old Feb 11, 2004 | 03:57 PM
  #267
BIGBOS's Avatar
Got an update from lee by the way........I guess he doesn't have any solution yet, mine are shipping tomorrow.........
5/16 "pins" and I ordered an extra belt just incase we throw it, but I don't think we will with the magic touch of the Sikora bros..........
250ftlbs sound good for the TQ level on the crank pulley with a whole lot of locktite?
Old Feb 11, 2004 | 05:26 PM
  #268
frcefed98's Avatar
Mine hasn't budged either(200ft lbs red locktite), should be on the dyno monday if all works out right.
With the Sikora's putting them on, maybe they will find a better solution to the tensioner pulley and spacing them out correctly. Definately keep me informed with pics of everything they do, if they do something different than I did.
Start a new post? Hell no this one still has room for your set up. No need to start 2
J
Old Feb 11, 2004 | 08:06 PM
  #269
1dirtyZ's Avatar
i only got 14 pages of info, where's the rest!?
i could see how this thread could seem tedious for someone that just started reading it.
if you just started reading this thread today and you are reading this mesage, good job!
Old Feb 11, 2004 | 09:10 PM
  #270
Keith's Avatar
I see only 7 pages, but then again I have it set so there are 40 posts per page.
Old Feb 11, 2004 | 09:53 PM
  #271
BIGBOS's Avatar
I got it setup so I see 27 pages....
Old Feb 11, 2004 | 10:10 PM
  #272
1dirtyZ's Avatar
back to the subject: i need more boost!
Old Feb 12, 2004 | 01:50 AM
  #273
BIGBOS's Avatar
Are you still with the 8 rib setup or are you waiting to see how we do with the COGS......
Old Feb 12, 2004 | 08:31 AM
  #274
1dirtyZ's Avatar
i need to stick with the 8 rib for a little bit more, then i'm definatly going with the cog setup.
i just need to get my truck running so i can finish up my camaro. i'm going to try a new combo so i wave to stick with the 8 rib setup to see what size pulleys i have to go with, then go to a cog setup from there.
Old Feb 12, 2004 | 04:18 PM
  #275
BIGBOS's Avatar
Sounds good......
Old Feb 12, 2004 | 06:39 PM
  #276
1dirtyZ's Avatar
you don't know how emotionally draining thi is! i have parts staring me in the face everyday, and i can almost hear them chant " install us....install us..."
Old Feb 16, 2004 | 03:59 PM
  #277
BIGBOS's Avatar
Jeremy any updates?
you gonna hit the dyno soon?
Old Feb 16, 2004 | 04:51 PM
  #278
NA$TY-TA's Avatar
Same here............ Jer any updates................ Il pm you later im at work now..... work nights now.
Kyle
Old Feb 16, 2004 | 06:42 PM
  #279
frcefed98's Avatar
Hi Bos and Kyle, I was going to hit the dyno today. But the car doesn't feel right...don't know how to explain it. Feels like something is loose, like the exhaust or something but there is nothing hitting anywhere or something in the driveline. Feels like something is out of balance(about the best way I can describe it) I will be checking my flexplate/converter bolts to see if one is missing. I also need to check my intake, I might have a small vacuum leak there. I want the car to be tip top before I hit the dyno with the boost it was pushing out the other day. Don't want to blow it up lol.
I need to take it to a local shop(Solid Technology) so Sean over there can check on my tuning to see if any red flags come up. Other than that, the cogs seem to be doing fine. I will be dynoing it this week or next monday for sure though.
J
Old Feb 16, 2004 | 08:41 PM
  #280
NA$TY-TA's Avatar
Good to hear..... will you be dynoing on your slicks or strret tires??? Does Sean over at Solid Tech have Edit??? You going to lock the converter or?? Give ua a heads up before you go and are you going to tune on 93 octane??
Later
Kyle
J
