Turbo size precision 6765
I originally wanted to run TC units because of the tight fit in my car.
Now I have seen Precision came out with their Vband turbine inlet so I would rather pursue that rout, now I just need to know if the compressor housing would be bigger than that of a Turbonetics TC unit.
Thanks!
If it has the "E" comp cover (3" inlet 2" outlet) it is the same diameter as well.
It looks smaller but I have both in my shop and they are the same size.
What do you guys think that is relative to, a t3 ar or t4.
I don't want to be choking this thing out with a twin setup because the housings are basically a t3.
I can't find any information on this, and if they were equivalent to t4 I would be golden
It is not an overly large turbo but it can make some really good power. The outlet on the one I have is 2.5"OD.
I.just bought a billet precision 6765. it came with a vband in vband out turbine housing.... anyway aren't these concidered P trims? im trying to swap out a turbonetics .81 p trim. t4 in vband out housing and for some reason it doesn't go down all the way. I even tried a master power p trim .68 won't work. what turbine housing is the precision?
UOTE=westtexasbuff;17441154]From left to right... PT88, Magnum 76, PT66... The Magnum has the same size compressor cover as the TC series turbos. The PT66 has the bigger H Compressor cover, 4" inlet, 3" outlet.
[/QUOTE]
