master power sizing
Old Jan 16, 2010 | 05:16 AM
dimetweaker's Avatar
Default master power sizing
Well since im riding a boat across the gulf of alaska I figured I would throw this out there for entertainments sake...
I am building an s-10 for street/ strip fun ( mostly street really ) and I bought an L92 to run in it. Forged rods and pistons ( 382 ci ) , 10.1:1 cr, stock heads and truck intake, custom cam for a turbo from texas speed, stock L92 heads. TH350. Dont really have a HP goal/ ET goal ( though bottom 10s would be swell )
I was wanting to run a MP t 76 but im wondering if its going to choke off the motor in the upper revs? I want decent spool down low ( strong boost by 3000 or so ) but I would sacrifice that to some extent to have something that keeps pulling hard to 6500 rpm +. thoughts?
Ive really been thinking of going twins but I just dont think its something I want to tackle on my first turbo build.
Old Jan 16, 2010 | 10:29 AM
TT350's Avatar
The Q trim with .96 a/r is the way to go with the MP76.
Call Rob at Modular turbo. He'll hook you up!
Old Jan 16, 2010 | 11:13 AM
well I wont be calling anyone on the phone for a few weeks given my location, but I had planned on buying my turbo(s?) from modular when I finally had a good idea what I want.
Old Jan 16, 2010 | 12:08 PM
XtremeDime's Avatar
What are you doing in my waters??? lol
Old Jan 16, 2010 | 02:41 PM
going to work! ill be in spanchorage next month too
Old Jan 17, 2010 | 04:54 AM
No other opinions? Bumpity bump bump....
Old Jan 17, 2010 | 05:44 AM
XtremeDime's Avatar
Go with a t78, it might be a little higher of a spool than in your OP but it will pull the whole way through.
You should move here! I need more people to work on my car. My buddy has a bagged s10 with an ls6 in it and back when I had my xtreme I had planned on something similar but ended up just dropping and shaving it.
Old Jan 17, 2010 | 11:01 AM
kbracing96's Avatar
The T76 is the biggest turbo MP currently makes. The Q-trim turbine is actually a 1.0 a/r, and 3" vband outlet. Would work very well on your proposed setup!
Old Jan 17, 2010 | 05:12 PM
MUSTANGBRKR02's Avatar
What about the 88?
Old Jan 17, 2010 | 07:55 PM
you think a 3" downpipe is enough for that many cubes? And yes, what about the 88, I forgot that beast was making its appearance here
Old Jan 17, 2010 | 08:30 PM
kbracing96's Avatar
You can step it up to a 3.5 right after the v-band if you want, but I've seen a 3" down pipe run mid 10's on a 6L in a 4900lbs 4x4 truck.
Old Jan 18, 2010 | 09:03 AM
I meant to ask when I PM'd you, but whats the TC78 good for HP wise before its just blowing hot air?
Old Jan 18, 2010 | 12:47 PM
kbracing96's Avatar
I think there are some guys pushing them into the 800's on here
