LSX 427ci Turbo?
Old May 22, 2009 | 05:08 AM
COOKIE MONSTER's Avatar
Default LSX 427ci Turbo?
I'm having Billy Briggs build me a Hydro roller 427ci, to run on pump gas. My question is, what size turbo should I be looking at. I found a 106mm almost new. But is that too big?
Old May 22, 2009 | 06:05 AM
HUNTER02SS's Avatar
Depends on how much power you are looking to make. Street or strip or both?
I am using a 94mm with my 427. That will be plenty for me for now.
Old May 22, 2009 | 06:27 AM
veee8's Avatar
Matt, you pick up the 106, I will loan you my GT47-88, I will test the 106 for a while, then when you are ready I will upgrade and you can put the 106 on. Sound like a plan?
Old May 22, 2009 | 06:38 AM
Denali08's Avatar
Yah, depends on your goal and intended use of the car!
106mm is over for street use and daily driver but works good for drag race 427ci LSX car with right setup.
Old May 22, 2009 | 06:42 AM
You serious? lol
I'm not totally against that. Just wondering if an 88mm will be big enough on those cubes...?
Also, keep in mind. A 4,000.00 turbo is not cheap. I'd like to use it from new.
Don't really care about power goals... I'd like to go 8.50s-8.70s on pump gas.
The car will still be driven on the street... just not more than 2 a week...
Old May 22, 2009 | 07:09 AM
veee8's Avatar
Think of it as a training turbo.....that 88 would spool very fast with 427 cubes.
Are you stateside yet?
Old May 22, 2009 | 09:06 AM
HUNTER02SS's Avatar
Originally Posted by 1BDTRAM
You serious? lol
The 88 seems to work fine on Veee8's car. The 427 will spool it the turbo a little easier. 8.50-8.70's on pump gas? You plan on using methanol? I mean I plan on using pump gas as well, I am going to pump it out of my 55 gallon drum of race fuel into my tank. LOL!
Old May 22, 2009 | 09:11 AM
Phil99vette's Avatar
7 Second Club
427 + 106 is good enough for deep into the 7s @ 190+. Street car I'd go with somethign alittle smaller, something in the 90s.
Old May 22, 2009 | 09:24 AM
ScorpionT's Avatar
106 is big for the street, I think the GT4788 or a PT91 would be better. A GT55 91mm or 94mm would be nice too.
Old May 22, 2009 | 10:30 AM
DrTurbo's Avatar
LS1TECH Sponsor
GT5018......Nothing more then a GT55 back half with a GT47 front half.....perfect unit for the bigger cube LS based motors that intend on pulling street duty. Also can be built in a mid-frame package or full frame thumper.
Old May 22, 2009 | 10:42 AM
Denali08's Avatar
How big is it compared to S91?
Old May 22, 2009 | 10:54 AM
DrTurbo's Avatar
LS1TECH Sponsor
Same size on the compressor...turbine housing is just a little larger.
Old May 23, 2009 | 02:42 AM
thanks for the input. I guess I accidently made an offer on this already.
http://cgi.ebay.com/ebaymotors/Preci...031010007r2501
DrTurbo:
PM sent
Old May 23, 2009 | 10:52 AM
Anyone else have any more input?
Old May 23, 2009 | 11:34 AM
ScorpionT's Avatar
I like the idea of the 5018. Turbine big enough not to choke out up top, but a smaller compressor thats better on the street.
Old May 23, 2009 | 12:25 PM
Haans249's Avatar
You made the right choice getting that setup. Even if you don't use it, you could use everything else that comes with it! 106mm would be sickly. You will be very happy with Billy building your motor
Old May 23, 2009 | 12:32 PM
Thanks for the advice guys.
