Turbo carnage
Old Feb 7, 2010 | 06:56 AM
LS69TA's Avatar
Default Turbo carnage
Apparently, turbos don't like rocks Somehow it still made 1lb of boost
Old Feb 7, 2010 | 09:18 AM
Lilsbc's Avatar
Ouch that's gonna hurt your pocket
Old Feb 7, 2010 | 09:47 AM
Blownz28man's Avatar
saw it was a cat turbo.. Nothing surprises me in industrial equipment....Most people would ask how that rock got there lol
Old Feb 7, 2010 | 10:07 AM
LS69TA's Avatar
Yea, was on a C7 Cat in a mine-resistant truck. Had 2 injectors get taken out as well, but management only wanted to put on a new turbo and intercooler. It had some noise at idle but ran ok so we had to roll it on out. I think some soldiers took the air filters out to try and get some more hp out of the engine or something. Either that or they pulled the filters and threw a handfull in there.
Old Feb 7, 2010 | 10:09 AM
LS69TA's Avatar
In the 2nd pic you can see a small rock still stuck in the housing.
Old Feb 7, 2010 | 01:45 PM
elias_799's Avatar
when you took out the injectors did you see any rocks or anything in the cylinder ?
i have never seen a turbo that badly raped. i once seen one with a disintagreated exhaust wheel and that killed the motor, because some little parts went to the oil pan and the oil pump picked up and sent to the bearings
Old Feb 8, 2010 | 12:35 PM
LS69TA's Avatar
We were initially just gonna replace injectors because 2 showed up as bad on the computer and I didn't even think to take a look at the tips. Plus we decided to just unbolt the injectors this time and crank the engine over and blow them out...they went a good 10 feet in the air It wasn't until later that we checked the turbo after the injectors were long gone.
Old Feb 8, 2010 | 08:36 PM
DrTurbo's Avatar
LS1TECH Sponsor
Give us a shout, we do quite a bit of industrial turbos. Our Diesel side handles all the CAT, JD, Cummins, Perkins, Scania....etc
Old Feb 8, 2010 | 11:34 PM
GTOSE's Avatar
Now you have my attention
Eh, its fine.
Put it back in, turn it up, let it eat.
Old Feb 8, 2010 | 11:53 PM
elias_799's Avatar
^^^ lol, with a compressor wheel like that it will not build any boost
Old Feb 9, 2010 | 12:05 AM
ElkyRacer's Avatar
Oh god how I DONT miss workin for the gummamant! MRAP?
Old Feb 9, 2010 | 05:09 AM
InsaneDomestics's Avatar
He said it still made 1lb of boost
And this is why Air Filters were made
Old Feb 9, 2010 | 12:48 PM
LS69TA's Avatar
Lol...yep Kyle it's in a FPI Cougar 6x6.
Old Feb 12, 2010 | 12:44 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Wow, that turbo got absolutely owned. At first I thought I was looking at the turbine side and the blades had been pushed out by something. Then, I realized it was the compressor side and .
