which gauges and why?
Old Feb 7, 2010 | 03:48 PM
1slowfbody's Avatar
Default which gauges and why?
i'm new to gauges and i'm not totally sure which one to buy for the maggie set-up this one: Auto Meter Phantom Series, 2-1/16" Mechanical Boost 30 in Hg.-Vac./20 PSI Includes 6ft. nylon tubing, 1/8" & 1/4" NPT fittings.
or this one: Auto Meter Phantom Series, 2-1/16" Full Sweep Electric Boost/Vacuum w/Peak Memory and Warning (Boost 30 In Hg.-Vac./30 PSI) Full Sweep, Stepper Motor meter movement. Includes 8 ft. tubing or wiring harness. Includes MAP sensor. Includes T-fitting.
i'm thinking i'll need the electrical one for the new amp sensor especially but i'm not sure . . . or should i just ask Ed at LM Speed about it?
Old Feb 7, 2010 | 05:45 PM
Photochop's Avatar
Boost is boost-shouldn't matter which gauge you use, just get the mechanical one and plumb it into a vacuum line. I've got the mechanical one you posted for sale if ur interested let me know.
Old Feb 7, 2010 | 06:47 PM
litle88's Avatar
I like the Aeroforce guages, you get 1 and monitor 2 things. I have 2 and monitor Knock, misfires on 1 and soon the other will be timing and AFR. My friend in his GTO will also have the 2 Aeroforce guages with knock, oil pres and the other boost and AFR.
Also the guages can scan for trouble codes and delete them, and you can program a shift light too. Just my .02
Old Feb 7, 2010 | 10:38 PM
1slowfbody's Avatar
hmmmm i'll talk with ed about this also tomorrow when i call him
Old Feb 10, 2010 | 08:48 PM
smashmetal's Avatar
No body running the Westach guages? I don't have one in my TA but I do in my diesel tow rig and I really like it. Boost and EGT's all in one guage.
http://www.genosgarage.com/products.asp?dept=95
Old Feb 15, 2010 | 07:10 PM
shift_grind's Avatar
EGT's are needed in a maggie car.
Old Feb 17, 2010 | 09:04 PM
pdasterly's Avatar
aeroforce
Old Feb 17, 2010 | 09:12 PM
XtremeDime's Avatar
I got prosport boost gauge and the AFR that came with my dynojet wideband.
